camber kit install problem
Old May 13, 2003 | 02:44 PM
Stopher's Avatar
Default camber kit install problem
this morning i decided to make the most of my day and install my camber kit i got in the mail last night. i installed the passenger side kit no problem. when i got to the drivers side, i could not push the wheel back up into place. it feels like there is a problem with the axle somehow, like something inside one of the boots got disconnected. is this a possibility. i didnt see any similar problems when i did a search. any ideas would help...especially while it is still light out.
Old May 13, 2003 | 03:48 PM
98AccordEX's Avatar
Default Re: camber kit install problem (Stopher)
CV joint could have pulled apart. take it apart and put it back together. make sure you have new rings to hold the boot on. and beware cause theres a ton of grease in there
Old May 13, 2003 | 03:58 PM
Stopher's Avatar
that makes a lot of sense. i just got the axles less than two weeks ago. this kinda pisses me off. how do i take apart/out the axles?
Old May 14, 2003 | 04:47 AM
Stew Pidasso's Avatar
Default Re: (Stopher)
I would turn the outside of the axle while holding the inside to see if you can pop it back into place. Disassembling those is a very messy job...
Mfoehrkolb
Suspension & Brakes
21
Sep 23, 2012 09:41 PM
X93siX
12
Feb 11, 2008 08:39 PM
tegSB85
Suspension & Brakes
Aug 4, 2005 09:32 AM
White Lightnin
Jan 26, 2004 04:14 PM
_Not_So_Nice_Guy
May 22, 2003 06:48 AM
