A/C Problem
Old May 15, 2007 | 03:48 PM
Honda_Accord's Avatar
Default A/C Problem
I did do a search for the accords fourms. I found some useful information. Even a guy that seems to have the same problem with his, but it never got answered.
I live in tx, so i kinda want A/C. Sense i have bought the car 2 years ago it has never worked, i looked at the compressor and noticed the wire that goes to the plug (i bleive its one green covered wire) was broken, so i attempted to connect it back, and it worked , you can hear the compressor kick on when i click the a/c button, however when i bought the refilling a/c stuff with a gauge it reads 75 psi which means problem with something else other then low refrigerant. I been thinking mabey just a bad compressor, but it does kick on and off normally when i click the A/C button, could it still be a bad compressor? should i find one at a pick a part place or order one just to see.
Naming any other problems for me would be helpful. I would just think it didnt work b.c the wire was cut, but who knows. I bought it from a girl so im pretty sure the A/C was used reg. until that wire got cut by the belt.
thanks for any help
ps. no fuses blown and both fans come on
Old May 15, 2007 | 04:46 PM
YeuEmMaiMai's Avatar
Default Re: A/C Problem (Honda_Accord)
evacuate the charge and recharge the system it may be overcharged
Old May 15, 2007 | 06:08 PM
Default Re: A/C Problem (YeuEmMaiMai)
thanks man i did what you said and now it blows cold air , i appreciate the quick response
kin413
May 30, 2007 01:54 PM
amej8
Jul 12, 2006 02:12 PM
SlowTeg
Apr 20, 2005 08:04 AM
