a/c issues
Old Apr 8, 2011 | 03:51 PM
f22vtec1's Avatar
Default a/c issues
98 accord my air only blows out the bottom any ideas ? also it only blows hott air my compressor is out but still even when i switch to cold side still blows hott any ideas?
Old Apr 8, 2011 | 03:59 PM
slomofo's Avatar
GDD Member
Default Re: a/c issues
If your compressor isn't working, it's pretty obvious what the answer to your hot/cold problem is.
As far as it only blowing out of the bottom, do you have buttons or ***** on your heater control panel?
Old Apr 8, 2011 | 04:02 PM
f22vtec1's Avatar
buttons to controll up and down n defrost none seem to make a difference and i meant even if its cold out and it have air and cold it comes out FIRE HOT
i know i need a compressor
Old Apr 8, 2011 | 04:16 PM
slomofo's Avatar
GDD Member
Pop open your hood and look at your heater hoses where they go into the firewall. You'll see this:
Have someone else switch the **** from hot to cold. Do you see that thing moving?
Old Apr 8, 2011 | 05:29 PM
f22vtec1's Avatar
k will do ! thanks
Old Apr 27, 2011 | 11:11 PM
f22vtec1's Avatar
k back to this so what controls the switching of the air from top dash vents to the floor and so on ? because mine wont switch !
Old Apr 28, 2011 | 10:09 AM
f22vtec1's Avatar
bump
Old Apr 30, 2011 | 04:51 AM
poorman212's Avatar
Check the inputs to the mode control motor, don't have a 6th gen, on the 5th gen you can get to it from the drivers side looking up from the foot area.
Old Apr 30, 2011 | 06:28 AM
jwicecold's Avatar
Do you park under trees or anything?? Stuff gets in the vents.. As for your Hot air, it needs to be recharged. If it has been and wont stay cold you have a leak in the hose line or most likely right where it bolts into the compressor.. Check it out. honda A/C compressors dont usually go out.
leemcdaniel
Oct 17, 2010 06:29 AM
Reebok4146
Honda Civic (2001 - 2005)
Aug 23, 2008 03:53 PM
NoEx00
Mar 8, 2007 07:31 PM
_Spugen_
May 28, 2005 12:47 PM
AGPSuperstar
Apr 4, 2003 10:36 AM
