Quick CV Joint Replacement Question
Old 04-29-2010, 09:32 AM
ClarkRU's Avatar
Default Quick CV Joint Replacement Question
When I pop these suckers out, will transmission fluid pour out everywhere?
Old 04-29-2010, 12:44 PM
VTECn83's Avatar
Default Re: Quick CV Joint Replacement Question
Last time I did this was on my Auto 94, and I had no fluid come out.
Old 04-29-2010, 01:36 PM
RICKSAUTOMOTIVE's Avatar
very little if any. like at most maybe half a quart. it depends if the car is lifted level or if just the front is raised. if so you might get more fluid coming out
Old 04-29-2010, 03:42 PM
vediann's Avatar
if you have a manual transmission it will mostly all drain on the floor atleast it did on my 91 accord.
Old 04-29-2010, 04:50 PM
AtoZ's Avatar
That's a good point and one that often goes unmentioned. I did my axles but drained the fluid, thinking a stitch in time ... Helms says it is not necessary for one side [dont recall which side] ... BUT, as in "caveat" I wonder if Helms wrote that with the thought that the vehicle would be on a level lift ...
Old 04-29-2010, 07:01 PM
claud122003's Avatar
well, usually when replacing CV's you should drain your transmission fluid first. Always be sure to use the correct kind of trans. fluid to put back in, must be honda not any other brand. oh and the drain bolt is the little square hole that a 3/8 ratchet will fit into.
Mike8ike
Transmission & Drivetrain
07-30-2013 05:20 AM
jetspeedz
09-10-2008 08:29 AM
PrettyFastRide
01-10-2007 05:37 PM
Neondog82
08-29-2004 11:06 PM
Quick Reply: Quick CV Joint Replacement Question
