another D4 problem.
Old Oct 7, 2014 | 04:20 AM
rxtasyy's Avatar
Default another D4 problem.
Ive got the normal D4 issue (tranny limp mode) had to change a few engine parts on my 92 ex to get the cel to go away.
well tranny is still in limp mode. shift lock works when it wants and........
if i put the key in run position with engine off. the D4 goes away or is dim after a bit... but gets bright if I hit the gas pedal.
anyone ever hear of this before? is the gas pedal connected electronically to trans or tcu?
oh and just another thing I noticed. while resetting the ecu etc again this morning. theres noise under the dash behind the cluster. it has to do with the shift lock. and heres the kicker.... if I hit brake with car not running but in run I cant get out of park but if I hit the gas there is an audible click and I can shift out of park...
any ideas?
Old Oct 7, 2014 | 10:33 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: another D4 problem.
Sounds like there may be some wiring issues, remove the lower dash panel and get to searching.
PghRidgeline
Jul 23, 2017 04:21 AM
Cayman Girl
Jun 10, 2013 10:44 AM
ludesrv
Oct 10, 2007 11:43 AM
koolhatch
Aug 1, 2002 01:23 PM
