Air conditioning knobs don't illuminate
Old Jul 30, 2006 | 08:00 PM
biggusf's Avatar
Default Air conditioning ***** don't illuminate
The air conditioning ***** in my 96 accord no longer illuminate when I turn the lights on , but the weird part is everything else on the dash still lights up. I am thinking it's the lights just in the *****, but wanted to if there is a fuse just for those lights. If it is the lights, can anyone inform me of the easiest way to change them.
Old Jul 30, 2006 | 08:40 PM
specbb6's Avatar
Default Re: Air conditioning ***** don't illuminate (biggusf)
check under your fuse boxes, there is a diagram of the fuse's order and what theyre for.
Old Jul 31, 2006 | 03:36 AM
biggusf's Avatar
Default Re: Air conditioning ***** don't illuminate (specbb6)
I did, but I didnt see anything that would be just those two lights.
Old Jul 31, 2006 | 12:44 PM
ricebike's Avatar
it was on big deal w/ wifey's car... this & the lighted panel on the auto trans stick were d/t iffy connectors.
I usually give it a love-tap w/ my palm & it would light up... haha
I guess you'll have to remove the console for a more permanent fix.
Old Jul 31, 2006 | 04:07 PM
hondaccord's Avatar
Default Re: (ricebike)
check the light dimming control left of the steering wheel. I got eurolight gauges, and I can plug that controll in and have the climate controls work. The other option I have, the one I use is to just leave it unpluged so my gagues will work.
Old Jul 31, 2006 | 04:43 PM
biggusf's Avatar
Default Re: (hondaccord)
interesting. Well the dimmer **** is turned all the way up, but still no lights behind the air *****.
Old Jul 31, 2006 | 07:03 PM
75thRanger's Avatar
Default Re: (biggusf)
haha, I have this same problem with my 95 ex, although all I have to do is hit it with my fist and they usually come on. But as to the technical answer I dont have a clue.
Old Aug 1, 2006 | 08:29 AM
ricebike's Avatar
Default Re: (75thRanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 75thRanger &raquo;</TD></TR><TR><TD CLASS="quote">haha, I have this same problem with my 95 ex, although all I have to do is hit it with my fist and they usually come on. But as to the technical answer I dont have a clue. </TD></TR></TABLE>
scroll back up to my post... check for loose connections @ the dash to bulb assembly, but i'm lazy & my fist works great
Old Aug 1, 2006 | 11:22 AM
cpmike's Avatar
they are lit by a single #74 bulb. very common problem, it can either be burnt out, but more commonly related to a loose connection. the a/c control unit is all 1 circuit board, while the light that lights the **** is remotely connected by wires, which often get loose... try pushing on the leftmost Vent button as hard as you can, it usually works for me...
for best results, youll have to pull the dash trim off, pull the unit out, replace the bulb, and solder the 2 connections...
Old Aug 1, 2006 | 12:22 PM
wcsh86's Avatar
From: Mississippi (awful place, do not come to visit)
Default Re: (cpmike)
yea, I had that problem for a while on my 94, I have to hit it every time i turn the lights on. apparently it's not uncommon. just smack it a good one.
Old Aug 1, 2006 | 01:22 PM
hondaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggusf &raquo;</TD></TR><TR><TD CLASS="quote">interesting. Well the dimmer **** is turned all the way up, but still no lights behind the air *****.</TD></TR></TABLE>
try to pull it out, and see if it is connected right.
Old Aug 2, 2006 | 05:25 AM
cpmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord &raquo;</TD></TR><TR><TD CLASS="quote">
try to pull it out, and see if it is connected right.</TD></TR></TABLE>its not the dimmer ****, as all of the other dash lights work.
Old Aug 4, 2006 | 04:36 AM
biggusf's Avatar
anyone else?
Old Aug 4, 2006 | 04:45 AM
wcsh86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggusf &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?</TD></TR></TABLE>
did you try everything everyone suggested and it's still not working?
Old Aug 6, 2006 | 05:13 AM
biggusf's Avatar
Default Re: (wcsh86)
Funny enough, it did work by hitting the area around the *****. It lights up, but then I have to do it every time I turn the lights on. I wanted to actually see if there was a technical reason and permanent fix for the problem though.
Old Aug 6, 2006 | 10:41 AM
cpmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpmike &raquo;</TD></TR><TR><TD CLASS="quote">they are lit by a single #74 bulb. very common problem, it can either be burnt out, but more commonly related to a loose connection. the a/c control unit is all 1 circuit board, while the light that lights the **** is remotely connected by wires, which often get loose... try pushing on the leftmost Vent button as hard as you can, it usually works for me...
for best results, youll have to pull the dash trim off, pull the unit out, replace the bulb, and solder the 2 connections...</TD></TR></TABLE>
did you read my last post? i suggested that hitting it would probably work, but the proper fix would be to resolder.
Old Aug 6, 2006 | 05:04 PM
Zeus Zore's Avatar
that a good sign of bulbs needing replacment !
Soulman41
Sep 25, 2014 10:00 AM
Cor10Bal
Classic Hondas
Aug 24, 2012 03:30 PM
95integrags-r
Mar 30, 2006 05:41 PM
cdx280
Jan 29, 2006 03:46 PM
Mr Boston
Aug 7, 2002 08:22 PM
