acceleration problem
Old Aug 31, 2014 | 01:09 PM
saintbhts's Avatar
Default acceleration problem
hey whats up everyone i been having a problem while i accelerate. I press the gas but the car hardly goes and then starts picking up speed. what i did notice there is a rattling noise coming from the rear end like if its coming from the fuel tank. what can that be?
Old Sep 1, 2014 | 04:10 AM
Lost Again's Avatar
Default Re: acceleration problem
You give us almost no detail to try to help
Old Sep 1, 2014 | 05:04 AM
holmesnmanny's Avatar
Possibly it could be a clogged catalytic converter.
Old Sep 1, 2014 | 06:28 AM
Lost Again's Avatar
Yea, a bad/broken cat....lazy O2(s)....in need of a tune up....and a host of other things.
It would be nice to at least narrow down what year/engine it is. And any other helpful information (CEL is on, just had this work done, ect).
Old Sep 5, 2014 | 11:02 PM
saintbhts's Avatar
the cat has been replaced already, i did notice a noise coming from the gas tank when warming up
Old Sep 5, 2014 | 11:09 PM
saintbhts's Avatar
the cat has been replaced, o2 sensor is still good, tune up has been done recently
its a 94 accord f22b1 engine, no check engine light
recently replaced:
the cat
spark plugs
spark plug wires
distributor
cleaned out throttle body
changed fuel filter( filter was clogged completely)
the acceleration problem started after filling up the gas tank and it got worse when i refilled it again like a week later
another thing the car did completely didnt want to turn on once after running it after about half hour wont turn on again until about 3 hours of letting cool down
once thing i did notice a noise coming from the gas tank
Old Sep 10, 2014 | 03:28 AM
heidelberg's Avatar
I'm having the same problem with my accord 96 AT, if the engine is cold the acceleration is very good it feels like it came fresh from the factory but when I drive it around for 30 mins there is hesitation to run it feels like its crawling up hill. spark plug are new, oil changed, transmission oil changed, fuel injectors cleaned, belt are all changed, all break pads are new and wheels do rotate freely. what could it be? I went to honda dealer and told me they could not find the answer to my problem. any help please! Thanks
Old Sep 10, 2014 | 09:37 AM
rwfxp1's Avatar
A few things, check your ignition timing, it might be off. Buy, borrow, or steal (I won't recommend this option) a timing light and check it out.
Also check the TPS and MAP sensor for any problems.
Old Sep 12, 2014 | 08:55 AM
Lost Again's Avatar
And just how did you confirm this?
Old Sep 22, 2014 | 09:26 PM
saintbhts's Avatar
thanks everyone my problem has been solved it was the timing, my car is running like a champ now
B18C_DC2
Nov 3, 2009 04:35 PM
si937
Sep 19, 2005 11:31 PM
Spoon-EK9
May 3, 2005 01:16 PM
Twiet
Dec 6, 2004 02:04 PM
