ABS light is on
Old May 24, 2004 | 12:53 PM
xplaya29's Avatar
Default ABS light is on
my ABS light is on and it stays on for some reason i there something wrong or is there a way to turn it off?
Old May 24, 2004 | 01:42 PM
fw190bvi's Avatar
Default Re: ABS light is on (xplaya29)
ur ABS is not working when the light is on......common problem for 5th gen accords.....check out user rotarybzzz's signature
Old May 24, 2004 | 01:50 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplaya29 &raquo;</TD></TR><TR><TD CLASS="quote">my ABS light is on and it stays on for some reason i there something wrong or is there a way to turn it off?</TD></TR></TABLE>
What trouble code does it have stored?
Old May 24, 2004 | 01:56 PM
fw190bvi's Avatar
Default Re: ABS light is on (Chiovnidca)
doesnt it only store one at a time???
Old May 24, 2004 | 02:14 PM
Chiovnidca's Avatar
Default Re: ABS light is on (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">doesnt it only store one at a time???</TD></TR></TABLE>
??? IT can store up to 3 at one time. Why do you ask?
Old May 25, 2004 | 05:41 PM
xplaya29's Avatar
my brakes work fine but the light just keeps comming on?
Old May 25, 2004 | 05:45 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
??? IT can store up to 3 at one time. Why do you ask?</TD></TR></TABLE>
ive got same problem......but ive never cared to pull the codes....but i heard from somewhere that it can only hold like 1 code or something, and u cant tell what sensor is sending it, so its almost impossible to pinpoint the problem w/o spending $800 for a whole new ABS unit......
i dont care cause i dont like ABS
Old May 25, 2004 | 05:48 PM
92exrcoupe's Avatar
happend to me on my 92, i just pulled the fuse and plugged it back in and havent seen the light since
Old May 25, 2004 | 06:33 PM
Chiovnidca's Avatar
No, ABS codes are pretty specific, they usually point you right to the problem.
Old May 25, 2004 | 06:53 PM
obie1023's Avatar
Yo...my TCS light is doing the samething I have an 03 accord and I am pissed...they replaced the fuse and it still does it....I think it maybe a bad switch?
Old May 26, 2004 | 03:00 AM
Chiovnidca's Avatar
Default Re: ABS light is on (obie1023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obie1023 &raquo;</TD></TR><TR><TD CLASS="quote">Yo...my TCS light is doing the samething I have an 03 accord and I am pissed...they replaced the fuse and it still does it....I think it maybe a bad switch?</TD></TR></TABLE>
Old May 26, 2004 | 08:46 AM
fw190bvi's Avatar
is pulling an ABS code just like ECU codes???....i might as well check that
thats why i usually dont listen to everything i hear
Old May 26, 2004 | 10:34 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">is pulling an ABS code just like ECU codes???....i might as well check that
thats why i usually dont listen to everything i hear </TD></TR></TABLE>
It's similar. ABS should flash a code, pause shortly, then flash a sub code. Let us know what it showing.
Old May 28, 2004 | 04:52 PM
Juccord's Avatar
I disconnected my ABS and the light was always on too, so if you dont care about your ABS then just pull out the bulb from the behind the gauge cluster, thats what I did.
Old May 28, 2004 | 05:21 PM
Chiovnidca's Avatar
Default Re: ABS light is on (Juccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juccord &raquo;</TD></TR><TR><TD CLASS="quote">I disconnected my ABS and the light was always on too, so if you dont care about your ABS then just pull out the bulb from the behind the gauge cluster, thats what I did.</TD></TR></TABLE>
That sounds like alot of work. Wouldn't pulling the fuse be easier?
Old May 29, 2004 | 10:58 AM
Juccord's Avatar
Pulling it out is very easy, Its a couple bolts and clips (i think 2 of each)
anomale
Dec 14, 2005 06:10 PM
Shadow 1992
Jun 14, 2005 01:48 PM
Steezn4NOReason
Nov 3, 2004 09:22 AM
FatBoy4door
Oct 7, 2004 10:21 PM
RyanAutry
May 3, 2003 02:23 PM
