98 accord codes/problems
Old Apr 2, 2010 | 08:16 AM
TwistedC's Avatar
TRIAL USER
Default 98 accord codes/problems
Hey guys and gals
I'm probably acting like a "DAN" and asking the same question that has been asked 100 times, but I just can not find a solid answer. Although, I did find an old post here through google that GhostAccord posted. However, it is for a 96 found here https://honda-tech.com/forums/showpo...02&postcount=9 and I thought 98-2002 were different
But I am not even sure I can pull codes for all her problems. I'm kinda a toyota guy, so don't know much about moms honda. All I know is it is a PIMA
At first, her drivers window went out. She can not roll down any windows from the drivers side. But she can go to any other door and roll that window down. I changed out her main window switches and it didn't fix anything. Then her power steering goes out. It turns easy to one side, but not the other. So I need to replace the rack and pinion
But now she has a new problem. She will just be driving down the road and the car will quit. She can wait a few secs. to a couple of mins and it will fire right back up and be fine. Then the same thing happened 2 days later. Then the day after that. It isn't acting like it is the alternator at all.
Any ideas? will codes tell you electrical problems?
Thanks
Old Apr 3, 2010 | 08:51 AM
alkoholikwun's Avatar
Default Re: 98 accord codes/problems
window not working should be due to malfunctioning window regulator/motor.
car dying randomly should be due to to ignition switch, not including ignition tumbler.
Old Apr 3, 2010 | 10:26 AM
RICKSAUTOMOTIVE's Avatar
window issue can be a broke wire for the drivers door master swith. check that the main and fuel pump relays are good. they may be in the same unit
95accord-R
Feb 3, 2014 11:56 PM
codyJDM
Nov 3, 2008 04:33 PM
jca1972
Dec 27, 2005 11:03 AM
windcalmer
Aug 7, 2004 03:22 PM
cjwelch
Dec 11, 2001 06:23 AM
