96 accord ELD problem p1298 code
Old Jul 27, 2011 | 08:01 AM
kamikaze619's Avatar
Icon6 96 accord ELD problem p1298 code
so i have a p1298 code shooting now just replaced both o2 sensors and now im having the elecric load detector code shooting and i dont know how exactly to fix the problem i know the ELD is located on the circuit board in the engine bay closes to the firewall. Am i suppose to replace the whole fuse box or how to i get to the eld fuse on a 96 accord? thanks in advance guys
Old Mar 28, 2012 | 12:35 PM
demonsdc's Avatar
Default Re: 96 accord ELD problem p1298 code
i am having the same issue can some one shoot me a solution
Old Mar 28, 2012 | 04:58 PM
crispins's Avatar
unplug the ELD from underhood fusebox
plug 820 ohm resistor into connector like this.
use the wires the red arrows are pointing to.
This will bypass the ELD system and fix your error code at the same time
Old Sep 27, 2013 | 08:27 PM
pwizzle's Avatar
My dad's 2001 Accord is having this same problem and I was wondering if the bypass from the previous post would help. If it does help, does anyone have the picture that was posted so I can use it as a reference?
Old Sep 28, 2013 | 12:06 AM
holmesnmanny's Avatar
You don't want to bypass it. It's a very important component of the charging system. It looks like your car has the eld built into the fuse box assembly. At the very least check around the nearest junkyards and ebay for another fuse box assembly.
ThatGreenGsr
May 13, 2008 10:06 AM
flyinga
Feb 13, 2006 03:06 PM
robnmol
Oct 26, 2004 04:14 PM
accord 01
Apr 26, 2003 11:33 AM
