94 EX with Code 22
Old May 16, 2019 | 08:58 AM
Fitz Williams's Avatar
10 Year Member
Default 94 EX with Code 22
The car is a 94 Accord EX and is showing a Code 22 which I see means VTEC pressure switch malfunction. Is the normal/usual solution to replace the switch? Or is there some other issue that comes up?
Old May 17, 2019 | 02:22 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 EX with Code 22
Simple test would be to see if there is continuity at the switch with the engine off.
Unhook the connector and check for continuity. If the switch has no continuity, then it is most likely bad or stuck open.
loudlownslow
Jul 7, 2013 05:05 AM
joshua89
Jul 30, 2011 01:36 PM
maneedman
Jan 8, 2006 07:26 PM
jaymar88
Apr 21, 2003 04:06 PM
