Engine loud 94 honda accord lx
Old 03-02-2011, 04:22 PM
johnny_honda's Avatar
Icon2 Engine loud 94 honda accord lx
I have 194k miles on it and the engine is loud. Doesn't knock, just seems loud. Is that just because the engine has so many miles on it? Can I do anything about it to lower the engine noise? What should the tach reading be?Thanks.
Old 03-02-2011, 07:31 PM
nus_dogg's Avatar
Default Re: Engine loud 94 honda accord lx
If the engine's loud, you need to adjust the valve lash. Factory spec is 0.010" intake side & 0.012" on the exhaust side using a feeler guage. The Tachometer should read 700-800 rpm at idle(hot).
Old 03-02-2011, 07:38 PM
quickster's Avatar
he is right. You need to do a valve adjustment whenever your engine gets loud like that.
Old 03-03-2011, 04:01 PM
SHAME ON YOU REBECCA!
kidcool1977's Avatar
Do you have a cold air intake in your engine bay?
Old 03-04-2011, 05:22 PM
poorman212's Avatar
"Loud"??? Can you help with a bit more detail?
Ticking, clicking type-yes check valves....also be sure the exhaust manifold isn't cracked. The stock ones are kind of "known" for doing that....I've replace mine two or three(maybe more?) times, everytime it was "loud"....my two cents.
curtie94
11-12-2011 09:47 PM
wskaggs
10-01-2007 09:27 PM
PogiGreg
02-28-2005 07:52 AM
vizion22
02-26-2005 11:14 AM
Quick Reply: Engine loud 94 honda accord lx
