2 problems....PLEASE HELP!!
Old Oct 27, 2009 | 07:31 PM
St3v3's Avatar
Default 2 problems....PLEASE HELP!!
1997 Honda Accord SE
Problem #1 - Turn signal fuse (7.5 amp) keeps blowing out. I put a 15 amp fuse in and now only the right signal works, left signal and hazards dont. If this is an electrical/wiring problem where should I look first and what should I be looking for? A photo or diagram would help a bunch.
Problem #2 - Radiator fluid is leaking but all the hoses are fine. Fluid is leaking around the front right axle.
Please Help!
Old Oct 28, 2009 | 11:35 AM
tamadrummer1120's Avatar
Default Re: 2 problems....PLEASE HELP!!
for "problem #2" what color is fluid that is leaking around the right axle?
Old Oct 28, 2009 | 11:48 AM
Simkin314's Avatar
Assuming I understood correctly...
First off, take out the 15 amp fuse. You really shouldn't replace fuses with larger current capacities than what they are rated for. That could result is melting wires and / or starting fires. Next, check the bulb itself. In unusual burnout situations (especially while hitting bumps and the like), it is possible for the electrical 'nodes' within the bulb to short to one another thereby reducing the resistance while disallowing the tungsten (or whatever is used in your specific bulb) to pass the necessary current in order to yield light. Next, visually check the light plug wires and the like, near / on the light fixture.
Old Oct 28, 2009 | 12:22 PM
CDdubz5's Avatar
now i am new to accords but is there a heater bypass plug on the block? because that could also be a cause of your coolant loss. also it is a good idea to go through and replace all the coolant hoses that have not already been replaced in the life of the vehicle because the rubber deteriorates a little and dries out. its just a little bit of preventative maintenance.
Old Oct 28, 2009 | 01:13 PM
i was thinking something like that, the coolant hoses used for the heater reasons, but when he said around the axle it made me think if the trans cooler has a leak into the radiator some of the coolant will get into the trans fluid and could leak out of the axle seal.....i guess.....*shrugs*. Thats the only idea that could have coolant leaking arund the axles.....and that is farfetched to even say that statement.
Old Oct 28, 2009 | 01:51 PM
cstone's Avatar
OH NO DUDE!!!! your flux capacitor got coolant on it! your car will explode in 3 days!
haha anyways, Simkin314 is deffinatly right about using higher rated fuses. If the recommended ones are blowing there is a problem which needs to be fixed. A higher fuse will most likely make it worse not better.
Old Oct 28, 2009 | 02:09 PM
CuteAccord's Avatar
You probably have the coolant leak right under your distributer. Check the little rubber hose that is under the distributer. It is probably trickling down to your transmission, and then to the ground. Happened to my Accord, and my cousin's.
Mrx733
Honda Civic (2001 - 2005)
Nov 18, 2006 09:50 AM
jli18
Audio / Security / Video
18
Jul 25, 2006 07:54 PM
101998
Jun 19, 2002 10:15 PM
