What is to tight?
Old 06-03-2011, 03:31 AM
ndiehm's Avatar
Default What is to tight?
I replaced the oil pan and gasket on my 94 accord. I noticed that the gasket had broken in half in one place. I'm not sure if I over tightened it and that caused the break. How tight should I tighten it? Should I tighten it to where the gasket is being squeezed out the sides or is that too tight?
Old 06-03-2011, 04:45 AM
gentek1145's Avatar
Default Re: What is to tight?
If you read a helms manual, it will give you the proper tq procedure + the tq ft.lbs rating.
If you over tighten the bolts, or don't tighten enough, it will leak.
Old 06-03-2011, 06:00 AM
StreetsideStig's Avatar
You'll need to get yourself a torque wrench. Just don't buy the crappy one from Autozone. I learned that the hard way.
Old 06-03-2011, 06:22 AM
ndiehm's Avatar
Do you know the specs on how much to tighten it? Or where can I find the info
Old 06-03-2011, 06:40 AM
H-T Order of Merit
TouringAccord's Avatar
Please remember there is a search feature
94-97 Accord oil pan gasket replacement
if you run across any problems, run a search on "oil pan" in this forum and you'll find many threads discussing problems or issues people have had when doing this to their cars.
Old 06-03-2011, 06:45 AM
Jmb106jr's Avatar
The torque spec is about 10 lbs, and it is done if memory serves me right in 3 stages and a sequence. You can find a down loadable Manuel for free online w/ a Google search.
defaced8
03-14-2007 05:15 PM
mondo375
03-11-2007 07:05 PM
iheartintegras
01-21-2007 12:42 PM
firewalkerr
02-13-2006 05:56 AM
rewerbcrx
12-15-2005 06:23 PM
Quick Reply: What is to tight?
