01 v6 accord no start checked everything and no start still?
Old Oct 20, 2010 | 12:45 PM
hondaon18's's Avatar
Default 01 v6 accord no start checked everything and no start still?
I have a 01 Honda accord v6 with no start at all everthing. Lights come on but nothing happens
Old Oct 20, 2010 | 02:21 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 01 v6 accord no start checked everything and no start still?
no crank or no start? Starter?
Old Oct 20, 2010 | 02:31 PM
Targa250R's Avatar
be professional
When you turn the key to position III ("start"), does the starter crank the engine, but the engine just won't run on it's own? Or are you just getting a single "click" noise and the starter doesn't crank the engine? No noise at all? A rapid series of clicks?
If the starter does not crank, you may have an insufficiently charged battery, a bad starter, or a bad ignition switch.
Old Nov 12, 2012 | 06:13 PM
Em2sFinest's Avatar
I am having a problem with my accord v6 i changed out the dashboard harnesses and there is no start signal at the driverside fusebox. i changed the ignition switch same symptoms. it only clicks, i also checked the starter its isnt getting any power to turn from the engine harness. wat could the problem be?
thank you
steven253
Feb 11, 2026 01:48 PM
Benkaraffa75
Dec 18, 2017 12:22 PM
yankeesullivan1
Feb 26, 2011 03:21 PM
jwicecold
Jun 9, 2010 03:31 AM
RUBZERK
Sep 18, 2004 05:13 AM
