ENTER THE CHATBOX BRO
i can either buy a 98 ex or a complete turbo kit with an sls ramhorn/3"dp, garrett .60 trim, tial 44mm vband wg, injectors/pump, chargepiping/fmic, comes with neptune evans tune, 3" exhaust...
decisions
decisions
damian...clearly you missed where i said garrett .60 trim. this isnt some horseshit 16g or ebay .50 trim on 6-8 lbs...
the kits in my friends ek 4dr sedan...ran 12.4xx on 12lbs with radials full interior with a sub in the trunk, open diff gsr trans, tune is for 16lbs but im not trying to destroy my motor in 3 months lol. i get the 3bar map, vac lines, oil lines...everything
guy said 10psi t3t4 tuned on s200. that car is making ALOT more power than the b20 and we ran his roll a 40 in an all motor car -__-
Nope he had drag radials upfront, we asked the guy to run at a light without even knowing the car was on boost, when we were next to him and we heard the loud *** external open i was like 0_0 banged third pulled a fender banged 4th and we were half a car infront, as for driver mod idk what type of PRO driver you need to be to mash the throttle at 40? Why you doubting the all motor b20 dahg?
horsepower between boost and all motor isn't the same. 250whp boosted b series=/=250whp all motor b series. ls on 10lbs with small turbo and a log manifold will make 230-240whp, add in long gears, spool time.... na b20v w/ 230whp=instant horsepower
no power adder? 230whp has a serious amount of power adders. most boosted b series setups make around 300whp with stock blocks. add a piston/rod setup and my kit will make 500+whp
JE 11:1 compression pistons
skunk2 pro2 cams
OBX intake manifold
hytech replica header
CTR trans
Tuned on E85
simple *** build.
still has room to go:
still has stock throttle body
stock head
Stock Sleeves
ebay header
and ebay intake manifold
Not even crazy compression.
