del Sol thread v 2.0!
Old Jun 2, 2009 | 01:19 PM
  #100976
.Sarge.'s Avatar
Default Re: del Sol Owner's Club Thread v 2.0!
Originally Posted by pinoy.solsi
lol sounds stupid but charge what?
your A/C system. It uses a coolant that has most likely lost its effectiveness. You need to recharge the system for it to work again.
Go to autozone and ask.
Old Jun 2, 2009 | 01:22 PM
  #100977
vicseg2's Avatar
with freon! but does ur car have ac first to begin with? u hook it up to that line between ur header and radiator, there should be a hose with a blue cap on top! but to do it the right way u want to suck up the air out ur lines first then charge it up so the air in ur lines wont freeze!
Old Jun 2, 2009 | 01:25 PM
  #100978
vicseg2's Avatar
cut n paste this on the honda tech search form. it shows u what to do! HOW TO: Charge your A/C air condition conditioner conditioning system at home.
Old Jun 2, 2009 | 01:56 PM
  #100979
vadimkag's Avatar
I would go to local michanik and do it right at first time. He'll do the vacum test and recharge it for you. That's what I did. I don't trust those auto store $9 crap it only work temporary if you do it right.
Old Jun 2, 2009 | 06:51 PM
  #100980
b16_sol_707's Avatar
If your ac system is is blowing warm air it's probably got a leak, you need to get that fixed so it won't keep leaking. I did a write up on it over on teamsolcal.com, but I can't access that site from my work computer. There's pictures there and step by step directions.
Old Jun 2, 2009 | 09:42 PM
  #100981
vadimkag's Avatar
Almost done with my cluster trim
Old Jun 2, 2009 | 09:44 PM
  #100982
Mwsol's Avatar
Nice.
Old Jun 2, 2009 | 09:45 PM
  #100983
Eran's Avatar
HT White Ops
Got a free lip today. Found a WWRS copy on the freeway.
Thing is in fine condition, just some superficial scuffs. Nothing that some elbow grease and some 400g won't take care of. Definitely tide me over until my BYS lip after the swap.
Old Jun 2, 2009 | 10:06 PM
  #100984
what cluster is that?
Old Jun 2, 2009 | 10:09 PM
  #100985
mugen-k's Avatar
s2000
unless you're asking ap1 or ap2?
Old Jun 2, 2009 | 10:10 PM
  #100986
nope, I just think it looks cool and didn't know what it was.
Old Jun 2, 2009 | 10:47 PM
  #100987
afro sheen's Avatar
free is free but the bys will look good on silver x2
Old Jun 2, 2009 | 10:48 PM
  #100988
honda_racing101's Avatar
Damn Jason you seriously snagged a WW lip off the freeway? Why can't I find cool parts just laying around?
Cali lean ftl.
Old Jun 2, 2009 | 11:23 PM
  #100989
Eran's Avatar
HT White Ops
Yep. I think it's a JDMSh!t copy, looks just like this:
Except ran over by a ricer. It was spraypainted gloss black too. Because urethane isn't glossy enough.
Old Jun 2, 2009 | 11:35 PM
  #100990
I need to get a lip
Old Jun 3, 2009 | 12:32 AM
  #100991
WrongWD's Avatar
i thought i got a deal when i got my jdm **** wwrs lip for $70
Old Jun 3, 2009 | 12:34 AM
  #100992
trustdestruction's Avatar
QUICK QUESTIONI(noob question)
a/c blows warm air.
what do i need for it to make it blow cold air?
=D
thnx my sol brothersss hehehe
Originally Posted by vicseg2
need to charge it! go to auto parts store! like ten bucks a can!
Err, don't just go throwing freon at your car...
First of all, what year is your car? 1993 (and possibly 1994, i don't remember) models use R12, which you can't even buy anymore. The newer models use R134a. If you do in fact need a recharge and your car has R12, get an R134a conversion kit from the store. Put the fittings on, but leave your refrigerant alone, do not drain it, and do not add to it. Take it to a shop and tell them you have R12 in the system, and you have R134a fittings on it, and you need the R12 vacuumed out and then R134a pumped in. Many shops can't vacuum R12, so you'll probably have to call around. Firestone is able to vacuum R12, I don't know about others. The entire service will cost approximately $100.
Secondly, if you were to use the kit at the store for recharging the system (not recommended), you need a different gauge than the shitty one-port gauge it comes with, you need a manifold gauge that reads from both refrigerant ports. I still recommend getting it done professionally though.
Next, you first need to know if that is in fact the problem... the easiest thing to do is go to a shop, and get an A/C diagnosis done for $20-40 (many places have specials during this time of the year for $20). Sometimes the diagnosis will be wrong though (happened to me...), so never go completely by what they say, and always get a second opinion... post your troubles on the forum to get more ideas.
Now, I want to ask you, if you look underneath the hood at the A/C compressor, with the A/C turned on and everything, is the compressor clutch engaged?
The pulley will spin freely on the compressor and you will see the pulley spinning when the A/C is off, but when you turn the A/C on, a clutch in the compressor will engage and then the entire metal cylinder sticking out of the side of the compressor will turn. There are some small bolt heads sticking out the side of the compressor wheel, you will see them spinning when the clutch engages.
If the compressor isn't engaging, then you just need to figure out why. In my case, the compressor relay was bad (it's right next to the driver's side headlight and cylinder head ground). Other people have experienced wiring issues such as frayed wires around the compressor causing the condenser fan fuse to blow (runs on same circuit), or even the wire from the relay to the compressor being sheared or completely disconnected.
Old Jun 3, 2009 | 05:56 AM
  #100993
RNPoo7's Avatar
Old Jun 3, 2009 | 06:15 AM
  #100994
RNPoo7's Avatar
Boosted people, are you guys running OEM or cometic head gasket?
Old Jun 3, 2009 | 06:52 AM
  #100995
vadimkag's Avatar
I been runing Cometic head gaskets forever with no problems.
Old Jun 3, 2009 | 07:23 AM
  #100996
JtriX21's Avatar
oem. then again all i did was throw some gsr cams at mine. lol
Old Jun 3, 2009 | 09:18 AM
  #100997
305S0L's Avatar
new pic
Old Jun 3, 2009 | 10:36 AM
  #100998
mugen-k's Avatar
golden eagle aka oem HGs
also GE head studs > ARP
Old Jun 3, 2009 | 12:09 PM
  #100999
B16DelSlo's Avatar
Originally Posted by 305S0L
new pic
how do they take pics like that?
Old Jun 3, 2009 | 12:20 PM
  #101000
Mwsol's Avatar
OEM
