DA Integra's Only
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
just talked to the guy, he said he'll refund me my $380 for the trans, i MIGHT be picking up a b16 cable trans with lsd from a friend (going to get a bill of sale this time) they are reputable though, but ill get the bill just incase haha
well I went through 1st all the way to third, at about 6k rpm the car felt like it hit a wall, so I shifted to 4th, got into it again and same thing happened, the car drove to the booth fine and to the pits fine, then I turned it off and let it sit for 2 hours, and tried to start it, no luck, it would try to turn over, but it just wouldn't. we checked everything and it all was ok, so we pop started it, ran fine. drove it home and 2 miles from my house just bogged out and died, we hooked a tow strap up to it and towed it to my house. I got up this morning and tried to start it, but it didnt work.
thats what 3 people said, I hope thats it and not something worse, Im going to check that out when I get home from work, I haven't replaced that yet.
oh, I forgot, my tube from my Im to my fpr was off, don't know for how long, but I could have swarn it was on when we were looking for the problem, but we could have over looked it. I will also swap out the plugs to see if that is the problem.
I'm thinking some reclinables but idk if you could get those low enough like you could a bucket.
I need to redo the rear section of my exhaust too. I'm trying to source some dual tips with a 2.5" inlet and keep the tips looking as stock possible. I really like the HKS tips but good luck to me finding some of those. Maybe I can do something with the stock tips...
as for the tips ima get some T1R tips but ima experiment before i swap it up..ill take some pics since we have the same exhaust u might like some of the stuff i do and give you some ideas
im having the same problem and ima get a bride low max seat..sat in a da with it and my helmet cleared the roof with a good 3 or 4in clearance...
![Emthup](https://honda-tech.com/forums/images/smilies/emthup.gif)
well we figured it out, we changed the plugs and switched out the relay, took a minute, but it fired up, let it idle, now shes back to normal, now I can get her straight.
been a while since i posted my DA..but as you can see ive been busy...![Happy](https://honda-tech.com/forums/images/smilies/emsmile.gif)
removed hiro bumper and fitted JDP carbon lip along with ambers..also seperated one pieces and painted housin black..also got the 92-93 bumper smoothed
what you think??
before....
![Name: 9D83F46B3CE6421E8D25B928338E20E8-50.jpg
Size: 72.2 KB](https://honda-tech.com/forums/attachments/group-threads-123/463649d1501528094-da-integras-only-9d83f46b3ce6421e8d25b928338e20e8-50.jpg)
after....
what you think??
before....
after....
![Name: DSC_0264.jpg
Size: 119.0 KB](https://honda-tech.com/forums/attachments/group-threads-123/463650d1501528094-da-integras-only-dsc_0264.jpg)
Teg looks good with the jdp lip, the only thing that i would change is the amber bumper lenses back to the clear ones but it looks good either way
have a couple b16 trans lined up already, one with lsd and one without, both from reputable people that i know, should hopefully be picking one of them up this weekend
just talked to my friend, im picking up the b16 cable trans with lsd and it'll be getting installed on wenesday while im at work, only problems with it is one leaking seal that my friend is going to replace for me. Cant wait
![Scared](https://honda-tech.com/forums/images/smilies/scared.gif)
i hope so too hahah, also found someone selling lug caps for my wheels for only $250! haha might just go ahead and pick those up as well and i'll have a complete set of mr5s
i really need to quit spending so much money lol
wats up fello DA owners
i got a little problem in my hands.
yesterday the car started overheating. pulled over and waited for it to cool down bought a gallon of water and as soon as it was cool enough, i checked the fluid......thing was almost dry!!! filled it up and drove it home. today i drove it for less than 30 miles and when i tried to start it, it had a misfire shut it off then back on and it was all better.... drove like a block away and boom!! started overheating. flipped it and cameback home....some fluid was gone and noticed some white smoke coming out of the exaust.
also found two tiny leaks on the radiator.
my theory is that the gasket for the intake mani is bad and need to replace that.....the radiator is a goner thats for sure but i wanna hear wat you guys think about it.
thanks in advance
thanks in advance
