Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
turboing jdm d15b vtec
Old Mar 3, 2004 | 12:37 AM
a1320honda's Avatar
Default turboing jdm d15b vtec
i have a 92 dx hatch with the jdm d15b vtec. boost is the next priority, does anyone know how this motor responds to boost? how much boost is enough for this stock motor? this is going to be my setup: hf manifold, 14b turbo, dsm sidemount, 2.25" exhaust, msd 255lph inline fuel pump, turboxs dual stage bc, dsm bov, hks turbo timer, b&m fpr, missing link check valve for map. does anyone on here have this setup and give advice for the instal. most of this stuff came off my 92 eclipse gsx, IE, free. any info is appreciated, also, does anyone know what this engines vtec switch point is and redline, i have an auto p28 conv. to manual, and the thing runs all the way to 7800
Modified by a1320honda at 1:58 AM 3/3/2004
Old Mar 3, 2004 | 01:57 AM
pissedoffsol's Avatar
25 Year Member
Default Re: turboing jdm d15b vtec (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 dx hatch with the jdm d15b vtec. boost is the next priority, does anyone know how this motor responds to boost? how much boost is enough for this stock motor? this is going to be my setup: hf manifold, 14b turbo, dsm sidemount, 2.25" exhaust, msd 255lph inline fuel pump, turboxs dual stage bc, dsm bov, hks turbo timer, b&m fpr, missing link check valve for map. does anyone on here have this setup and give advice for the instal. most of this stuff came off my 92 eclipse gsx, IE, free. any info is appreciated, also, does anyone know what this engines vtec switch point is and redline, i have an auto p28 conv. to manual, and the thing runs all the way to 7800
Modified by a1320honda at 1:58 AM 3/3/2004</TD></TR></TABLE>
try the FI forum
the ecu will control the redling and X-over, not the motor. p28s rev out at 7600, and x-over at 4400.
Old Mar 3, 2004 | 10:55 AM
a1320honda's Avatar
Default Re: turboing jdm d15b vtec (pissedoffsol)
what i was asking was does anyone know what the motor is capable of reving to, and what is the optimal point to crossover, i know what the p28 does. this engine ran on the p08, so i guess what im saying is, what is the redline if the p08 and the crossover.
Old Mar 3, 2004 | 11:04 AM
lohatch's Avatar
http://www.homemadeturbo.com
also i am unsure about your questions on the redline. i would also not run over 8 psi on your stock motor with your management, with some better managemant and some tuning you could run more. 5-6 psi would be rather safe using the FMU. make sure you know what you are doing before you raise it up. you shouldnt even need a boost controller because i think the WG opens at around 8 psi on the 14b and just from reading your setup i wouldnt suggest going higher. it depends how long you want the motor to run for
Old Mar 3, 2004 | 11:16 AM
a1320honda's Avatar
Default Re: turboing jdm d15b vtec (lohatch)
the wg opens at around 8psi, wouldnt i need the bc to limit it to 6-7 psi. also being in boise ID, what ratio fmu do i need, i was thinking about a 12\1. what i meant by the redline is i did a serch on this motor and everyone was saying redline is 7300, but the p28 reds at 7600, i know its only 300, but is this going to hurt the vavletrain or is this acceptable?
Old Mar 3, 2004 | 08:18 PM
a1320honda's Avatar
anyone?
Old Mar 3, 2004 | 08:55 PM
BooSTiN5thGeN's Avatar
i heard the you can rev the stock vlalvetrain to 7800 and it will be safe....i might be wrong, but if i am, someone will correct me
Old Mar 3, 2004 | 11:20 PM
Formula 1's Avatar
Default Re: turboing jdm d15b vtec (BooSTiN5thGeN)
is this the 3 stage vtec engine?
Old Mar 4, 2004 | 02:40 AM
a1320honda's Avatar
Default Re: turboing jdm d15b vtec (SikCivic)
nope, just regular ol vtec in intake only.
Old Mar 4, 2004 | 03:14 AM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">what i was asking was does anyone know what the motor is capable of reving to, and what is the optimal point to crossover, i know what the p28 does. this engine ran on the p08, so i guess what im saying is, what is the redline if the p08 and the crossover.</TD></TR></TABLE>
it's almost identical to the z6, so i think you are best bet to leave the p28 in control.
optimal, you'd have to find out on a dyno.
Old Mar 4, 2004 | 09:11 PM
a1320honda's Avatar
what about all the turbo stuff, any got this setup?
Old Mar 4, 2004 | 09:16 PM
Tad's Avatar
Tad
there is a section devoted to forced induction,
go there and ask about forced induction stuff.
the dx has fuelcutoff at 6400rpm
Old Mar 21, 2004 | 12:25 AM
SweetAzCivic's Avatar
Default Re: turboing jdm d15b vtec (Tad)
turbo d15b in a hatch will be killin foolz
Old Mar 21, 2004 | 06:00 AM
mycivicstoo(s)low's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">the dx has fuelcutoff at 6400rpm</TD></TR></TABLE>What's that have to do with the topic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweetAzCivic &raquo;</TD></TR><TR><TD CLASS="quote"> turbo d15b in a hatch will be killin foolz </TD></TR></TABLE>
Old Mar 25, 2004 | 09:36 PM
TomC's Avatar
Default Re: turboing jdm d15b vtec (mycivicstoo(s)low)
Friend of mine is running a setup close to this on 14psi , been doing so for about 6mts .. No probs as of yeat just tune it
Old Mar 31, 2004 | 07:17 AM
SOHC_MShue's Avatar
are you even making power to 7800?
Old Mar 31, 2004 | 08:53 AM
a1320honda's Avatar
Default Re: turboing jdm d15b vtec (SOHC_MShue)
this motor with the dx tranny pulls incredibly strong all the way to red. even in tall *** 4th. this motor and i/e and being gutted is already fast as ****. i raced my buddy with a 99 si with i/h/e and beat him by a car and a half to 100. every one around here is already worried about when i turbo this thing.
Old Apr 1, 2004 | 10:14 PM
a1320honda's Avatar
anyone else?
Old Apr 2, 2004 | 08:32 AM
1990hondaHF's Avatar
vtec x-over for the d15b vtec is 4800 under full throttle and 5000 or 5200 under light throttle....at least that is what my vtec light says I think this is one of the best "D" engines to boost because a good amount of them are low mileage vs USDM d16's...try to find one of those with under 50K miles...can be done but $$$$! There was a guy on here boosting one of these(I think his name was "eg6turbo"), he had stock internals, running 10 PSI...he threw down a 13.6 in the 1320! I don't care what you say, that is fast!.....as for ECU's....use the P08. It has more aggressive fuel maps for the cam, which is also more aggressive then the Z6's....Reving it to 7800? I would beat my friend *** if he did that in my car! Readline is there for a reason.....and lets face it, with a boosted civic, all they will see are your tail lights anyway...so there isn't much need to spend too much time in the red zone ....but that is just my opinion.
Old Apr 2, 2004 | 09:36 AM
Slammd Sol's Avatar
i heart my turbo d15b.. on just 5psi I smoked a GSR swapped civic.. 1990hondaHF, we gotta meet up up sometime so i can check out your ride, I am right in Orlando by UCF
Old Apr 4, 2004 | 09:46 PM
Default Re: (Slammd Sol)
I'm in Melbourne....when is the next Honda meet? I missed the CRX one last year....
Old Apr 9, 2004 | 11:30 AM
13link EG's Avatar
6 pnds is safe of the totaly stock d15 b, you will be pretty close to 200 hp at the fly wheel, which is very nice
Old Apr 9, 2004 | 01:14 PM
Nextelbuddy's Avatar
Default Re: (13link EG)
why is this post even in the sponsors area? it shouldl have been moved to the proper forum by now
Old Apr 10, 2004 | 03:57 AM
Default Re: (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">why is this post even in the sponsors area? it shouldl have been moved to the proper forum by now </TD></TR></TABLE>
Humm....says forced induction on my computer screen....
Old Apr 11, 2004 | 04:02 PM
TorganFM.'s Avatar
Default Re: (1990hondaHF)
Yeah I click this forum all the time trying to get to the FI info (not sponsor) page.
