Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Turbo blocks. from basic build up to Full competition sleeved blocks.
Old Mar 23, 2004 | 09:06 AM
ExospeedAMcrx's Avatar
Default Turbo blocks. from basic build up to Full competition sleeved blocks.
Exospeed Race Engines:HT Special
Many different stages to choose from. check to see if there is a setup that is perfect for your needs.
Every part used is Top Quality Parts. We only use Honda Bearings and Honda oil pump, water pumps and gasket sets. You won’t see non-honda bearings or aftermarket replacement parts on our Race Engines. All block packages require core.
All block packages come with the following:
1. New OEM Honda Bearings
2. New OEM HONDA VTEC Oil pump
3. New OEM Honda Water Pump
4. Micropolished crank
5. Bottom end Gasket kit
6. Bore, Hone, deck, hot tank, R&R rods(if neces)
7. Assembly of block
B-Series
Turbo 1.6L-B16 / 1.8L block $1645.00
1. Arias 81.5mm 10.6-12.2:1 pistons w/ rings (compression will depend on the head and block used)
B16A head-B16Block 8:1 or 9:1
B16A head-LS Block 9:1 or 10.1:1
GSR head-LS block 9.2:1 or 10.4:1
GSR head-GSR block 9:1 or 10.1:1
2. Stock rods
Turbo 84mm 1.8L-B16 /2.0L race/street block $ 2695.00
1. RS Machines Sleeving
2. Exospeed Race sleeves
3. Arias 84mm
B16A head-B16 block 8.2:1 or 9.5:1 84mm
B16A head-LS block 9.2:1 or 10.6:1 84mm
GSR head-LS block 9.2:1 or 10.9:1 84mm
GSR head-GSR block 9.2:1 or 10.8:1 84mm
4. Eagle Rods
Turbo Custom Bore / Custom Piston Race block $2845.00
3. Eagle Rods
4. Arias Pistons: custom bore, custom compression to your specs
For the D-series Fans out there
D16A6, D16Z6, D16Y8, D16Y7
Turbo D16 $1645.00
1. Arias pistons w/ rings
D16A6 setup: 8.5:1 75.5mm
D16Z6 setup: 9:1 75.5mm
D16Y7 setup: 9:1 75.5mm
D16Y8 Setup: 9.3:1 75.5mm
2. Stock rods
Turbo D16 w/ Eagle Rods $1965.00
Turbo D16 Street/Race block $2695.00
1. RS Machine sleeving
2. Eagle Rods
3. Arias Pistons w/ rings(see compression above)
Turbo D16 Race block $2845.00
1. RS Machine sleeving: your specified bore size
2. Eagle Rods
3. Arias Pistons w/ rings – Custom bore and compression size
All packages require core. Some cores available, inquire for availability
Old Mar 23, 2004 | 10:18 AM
Rob Dizzle's Avatar
Default Re: Turbo blocks. from basic build up to Full competition sleeved blocks. (exospeedAMcrx)
dude, just change yoru name to exospeed
what is AMcrx supposed to mean anyway
bump for will, who is a great seller
Old Mar 23, 2004 | 06:59 PM
Charles B.'s Avatar
Default Re: Turbo blocks. from basic build up to Full competition sleeved blocks. (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">what is AMcrx supposed to mean anyway
all motor crx? dunno just a guess
Old Mar 25, 2004 | 10:53 AM
All Motor CRX is correct
but do you know what Exospeed means. hehe
Old Mar 26, 2004 | 09:04 AM
Default Re: (exospeedAMcrx)
bump
Old Mar 26, 2004 | 09:41 AM
Captn. Save A Hoe's Avatar
Drooooool
Old Mar 26, 2004 | 04:11 PM
tygsr's Avatar
Default Re: (The P.I.M.P)
I love mine! THanks Will..
Old Mar 28, 2004 | 08:00 AM
Default Re: (tygsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tygsr &raquo;</TD></TR><TR><TD CLASS="quote">I love mine! THanks Will..</TD></TR></TABLE>
thanks Tyler...
Old Mar 28, 2004 | 10:45 PM
B18C1_T's Avatar
any gsr block pre sleeved here?
Old Mar 28, 2004 | 11:38 PM
Default Re: (B18C1_T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_T &raquo;</TD></TR><TR><TD CLASS="quote">any gsr block pre sleeved here?</TD></TR></TABLE>
We have GSR blocks that we can sleeve.
Old Mar 29, 2004 | 12:12 AM
Old Mar 29, 2004 | 07:02 PM
B18C1_T's Avatar
WIL+SERVICE=
Old Mar 29, 2004 | 07:29 PM
quik sol's Avatar
WIL+SPONSORSHIP= My Dream!
Old Mar 30, 2004 | 09:33 AM
Default Re: (quik sol)
LOL.
Old Apr 1, 2004 | 11:25 PM
B18C1_T's Avatar
check pm dude
Old Apr 4, 2004 | 09:32 PM
B1Boosted's Avatar
From: from a lil town called none ya gatdamn business, usa
bump...might use svc in future
Old Apr 4, 2004 | 11:08 PM
quik sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">LOL.
I will take that laugh as a yes....so is this going to be a full or partial sponsorship? J/K...bump for a great company.....
Old Apr 5, 2004 | 04:35 AM
acr91's Avatar
do you h22 blocks
Old Apr 7, 2004 | 01:19 AM
Default Re: Turbo blocks. from basic build up to Full competition sleeved blocks. (acr91)
sorry for the late replies on PM and on here. We were gone 2 weekends in a row for racing and havent been on the comp much. anyways. we do work on H22 as well. from turbo setups to full competition all motor setups.
Old Apr 10, 2004 | 08:11 PM
B18C1_T's Avatar
can't wait to get mine.wooooooop yeah
Old Apr 10, 2004 | 08:38 PM
quik sol's Avatar
free bump for yalls name on DSport Magazine on the 10 second PRO AM FDW street civic hb running solid mid 10's
Old Apr 11, 2004 | 11:35 AM
Superorb's Avatar
no F block luv??
Old Apr 12, 2004 | 06:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">free bump for yalls name on DSport Magazine on the 10 second PRO AM FDW street civic hb running solid mid 10's</TD></TR></TABLE>
thank you!
We do H, F and K motors as well. not part of the list but we can design one for you
Old Apr 12, 2004 | 07:37 PM
quik sol's Avatar
Question with your head work package which is an awesome deal...and this bottom end package which is a killer deal also....can we have the whole engine done AND fully assembled and shipped or will you shipt the head/block seperate even if people do a full build up?!?!!?
Old Apr 13, 2004 | 12:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">Question with your head work package which is an awesome deal...and this bottom end package which is a killer deal also....can we have the whole engine done AND fully assembled and shipped or will you shipt the head/block seperate even if people do a full build up?!?!!?</TD></TR></TABLE>
Yes we can complete both the top and bottom and send it all bolted on, torqued and ready to go. we can ship it separate as well.
