Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Honda-Tech...
Old Oct 29, 2007 | 09:41 AM
Mexcivico's Avatar
Default Honda-Tech...
So Im About to make a decision of a lifetime... I have a 93 civic ex. I have had problems with it since i last replaced the engine last winter. So my hopes of fixing it have dwindled. I am debating whether taking out the old d-series and swapping in a k-series type r tho. I know its expensive but many isnt an issue. All im looking for is a 10 second all motor car and I think with the civic body being so light the k20 would do the job maybe supercharge like I wanted also. How much am I looking to spend?Is this an easy swap I bet its been done before anyone in here?Well anything will be helpful i just need a ball park estimate and where in chicago can i get this done?
Old Oct 29, 2007 | 09:46 AM
ItsSlow's Avatar
If you want a 10 sec all motor civic, I hope you have a nice stack of benjamins because that isnt cheap.. And you would also have to have more than a K20 to do it..
The swap is easy if you have the knowledge to do it and all the parts/equipment necessary to handle the task..
If you have never done it before and dont feel like you are up to the task, then Id highly suggest taking it to a professional shop..
Old Oct 29, 2007 | 09:48 AM
HarfordCTR's Avatar
Default Re: Honda-Tech... (Mexcivico)
Lots of people have done that swap. Turbo/supercharged. Its been done. It isn't a cheap swap by any means. Try using the search button up top. U can find all you want to know.
Old Oct 29, 2007 | 10:00 AM
Prism250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">So Im About to make a decision of a lifetime... I have a 93 civic ex. I have had problems with it since i last replaced the engine last winter. So my hopes of fixing it have dwindled. I am debating whether taking out the old d-series and swapping in a k-series type r tho. I know its expensive but many isnt an issue. All im looking for is a 10 second all motor car and I think with the civic body being so light the k20 would do the job maybe supercharge like I wanted also. How much am I looking to spend?Is this an easy swap I bet its been done before anyone in here?Well anything will be helpful i just need a ball park estimate and where in chicago can i get this done?</TD></TR></TABLE>
You want an all motor 10 second civic, but your talking about supercharging the k20?
I think you may need to search to see how difficult of a goal your setting. How much is it going to cost you? ALOT
Old Oct 29, 2007 | 03:09 PM
Mexcivico's Avatar
I want to swap a k20 type r engine into a civic ex... than if all motor mods wont get me in the tens than i will supercharge it. Im thinking bout 16-20 g's where is there a reputable shop in chicago?
Old Oct 29, 2007 | 03:13 PM
raphael's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">So Im About to make a decision of a lifetime... I have a 93 civic ex. I have had problems with it since i last replaced the engine last winter. So my hopes of fixing it have dwindled. I am debating whether taking out the old d-series and swapping in a k-series type r tho. I know its expensive but many isnt an issue. All im looking for is a 10 second all motor car and I think with the civic body being so light the k20 would do the job maybe supercharge like I wanted also. How much am I looking to spend?Is this an easy swap I bet its been done before anyone in here?Well anything will be helpful i just need a ball park estimate and where in chicago can i get this done?</TD></TR></TABLE>if money isnt an issue why are you asking how much will it be? also if u want a 10 sec. all motor hondas get a crx, gut it, swap in a highly modded and tuned k20/k24 motor and good luck
Old Oct 29, 2007 | 03:20 PM
Boost_V's Avatar
Default Re: (Mexcivico)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">I want to swap a k20 type r engine into a civic ex... than if all motor mods wont get me in the tens than i will supercharge it. Im thinking bout 16-20 g's where is there a reputable shop in chicago?</TD></TR></TABLE>
Damn, how much money do you have to blow. If that was the case, then you'd have to swap out pistons, and all the **** that makes a beast of an all motor car a beast. Then you'd have to go with low comp. pistons and everything else.
And a ten second all motor car on the street will probably never pass inspection.
And if you have 16-20 thousand dollars to spend for this hobby, I wouldn't put it into a 1994 civic ex. You might as well, get an RSX (already has a K) then build and boost it if you have that much money.
Old Oct 29, 2007 | 04:03 PM
Mario_D's Avatar
Consider other alternatives as well. Outside of Honda. If you have that much money to spend on this type of project.
A drag rail with a VW power plant.
Older "muscle car" with the appropriate small/big block.
Motorcycle.
m-
Old Oct 29, 2007 | 04:27 PM
ifIexplode's Avatar
16-20 grand?
Used STi FTW
Its gets to a point where if you have that much money. look beyond honda. as much fun as they are. but come on.
Old Oct 29, 2007 | 04:30 PM
bmoua's Avatar
Default Re: (Boost_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V &raquo;</TD></TR><TR><TD CLASS="quote">
And if you have 16-20 thousand dollars to spend for this hobby, I wouldn't put it into a 1994 civic ex. You might as well, get an RSX (already has a K) then build and boost it if you have that much money.</TD></TR></TABLE>
Very true, the rsx-s isn't a bad chassis to start with...but i still love my civic though
Old Oct 29, 2007 | 04:37 PM
posHonda's Avatar
This is just a track car right? After everythings done its not going to be much of a convenient sreet car.
Old Oct 30, 2007 | 05:00 AM
Mexcivico's Avatar
I already have an RSX but it's an auto and i only bought it cuz the civic was giving me a headache. I was thinking maybe swapping a type r in there but i wouldnt know where to start or get it done plus i heard that it might not fit in the engine bay. So my civic ex is the only bet
Old Oct 30, 2007 | 05:11 AM
Probot's Avatar
dude - take your RSX and swap the RSX Type-R motor into that..the motor should drop right in. i know you said money isn't an issue, but you will save a ton since all you really need to do is drop the motor in. then you have a ton more money to make the car faster than god.
swapping it into a civic is a headache..and if you bought the RSX cause the Civic was giving you a headache (for god knows what reason), swapping a k series into it does not equal aspirin.
EDIT: if you swap the RSX, swap the trans while you're at it cause you'll have to do it to the Civic as well
Old Oct 30, 2007 | 05:18 AM
cjk95delsolsi's Avatar
If you want a good shop in Chicago where you can buy the engine and have it installed within a day or 2, eric japan engines. I dont have there card anymore but you can look them up. He gives warranties too. Also you can usually hagle the price.
Old Oct 30, 2007 | 05:20 AM
http://www.nexport.com/company...GO_IL
Old Oct 30, 2007 | 05:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I wish I had a dollar for every stupid ******* topic where some "rich" kid comes in asking stupid questions and saying he has an unlimited budget.
If you're so ******* rich why did you buy an auto RSX for a daily driver?
Theres a link for ya, He has a nice selection of JDM engines.
Old Oct 30, 2007 | 05:23 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">So Im About to make a decision of a lifetime... </TD></TR></TABLE>
By the way deciding on what swap you're not actually going to do in your car isn't a ******* "lifetime" decision - marrying someone, deciding whether or not to have kids, buying a house, etc. etc. - these are lifetime decisions.
Are you 17? I have a feeling you might be...
Old Oct 30, 2007 | 05:33 AM
Probot's Avatar
Default Re: Honda-Tech... (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you 17? I have a feeling you might be...</TD></TR></TABLE>
wow, i completely agree with you B18C5-EH2 - dropping 15-20 grand on a civic would be the dumbest decision as far as "decisions of a lifetime" go. you can take that and put a down payment on a house for christ sake, or save it for whatever future you planned for yourself instead of dumping it into a 15 year old civic.
Old Oct 30, 2007 | 06:10 AM
Mexcivico's Avatar
Ok so maybe it's not a decision of a lifetime but i've had it for over a year just sittin. I was gonna rebuild the d and run that all motor but I just got tired of ******* with it. I like my K and i've seen what they do when put in lighter cars like hatches or coupes run 13's stock. Type R all motor build will definately net me close but as always there's haters and I aint rich but I can afford whatever swap I please so expletive off asshold. If you didnt like wat you saw then why you reply move on damnit haters make me sick. And I bought an auto cuz Im lazy and the type s tranny have weak *** syncros sooner or later your gonna get popouts or lockouts
Old Oct 30, 2007 | 06:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">Ok so maybe it's not a decision of a lifetime but i've had it for over a year just sittin. I was gonna rebuild the d and run that all motor but I just got tired of ******* with it. I like my K and i've seen what they do when put in lighter cars like hatches or coupes run 13's stock. Type R all motor build will definately net me close but as always there's haters and I aint rich but I can afford whatever swap I please so expletive off asshold. If you didnt like wat you saw then why you reply move on damnit haters make me sick. And I bought an auto cuz Im lazy and the type s tranny have weak *** syncros sooner or later your gonna get popouts or lockouts</TD></TR></TABLE>
Okay you got me - I'm a hater.
I'm jealous of your auto RSX, and I'm jealous of your "$20,000 money ain't no problem" budget too. You got me pegged.
Actually I replied because I'm tired of seeing these exact same topics pop up once or twice a week, only to have others wasting their time/effort by endulging every e-fantasy build you kids type up.
I also wish I had a dollar for every guy like you who posted this exact same topic, yet never did the swap and dissappeared from H-T.
I don't know too many forums that enjoy a bunch of people wasting everyone's time by posting bullshit like "I want 10 second all motor, but I will supercharge it prolly yo" and "money ain't no thang y0!"
I mean, if i'm in the minority here and the rest of you guys enjoy seeing these types of topics with fantasy e-builds that will never happen then I'll stop typing up replies like this, and I'll kindly take my services elsewhere so that the true tech topics get overrun with e-racing bullshit.
Old Oct 30, 2007 | 06:57 AM
kuja396's Avatar
Default Re: (B18C5-EH2)
lmao thanks for the laugh, I got to thinking about it and if I was unlinited rich I would have at LEAST got a corvette dd lmao
Old Oct 30, 2007 | 07:02 AM
Mexcivico's Avatar
thanx cjk that shop is actually 10 minutes away from my house imma go talk to the guy since according to dicktech b18 i aint gonna do it. It aint an efantasy homie this is real life and others are more fortunate than you just cuz it was hard for you dont mean thats how its gonna be for everyone and dd corvette cmon now I like a gas sipper rather than a guzzler ever heard you got to pay to play ******
Old Oct 30, 2007 | 07:06 AM
Probot's Avatar
yea, but a 10 second honda isnt gonna sip gas either dude
Old Oct 30, 2007 | 08:02 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mexcivico &raquo;</TD></TR><TR><TD CLASS="quote">thanx cjk that shop is actually 10 minutes away from my house imma go talk to the guy since according to dicktech b18 i aint gonna do it. It aint an efantasy homie this is real life and others are more fortunate than you just cuz it was hard for you dont mean thats how its gonna be for everyone and dd corvette cmon now I like a gas sipper rather than a guzzler ever heard you got to pay to play ******</TD></TR></TABLE>
Yeah you're right - I'm poor too.
Do I need to post pics of my house, three cars, two motorcycles, etc. etc. to prove something to you kid?
**** off. Go back to ClubwhattheFuckEver or where you came from.
