Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Golden Eagle Mfg. Sleeved Block Core Exchange Program
Old Dec 22, 2004 | 10:41 AM
X-Mazda 3 Racer's Avatar
Default Golden Eagle Mfg. Sleeved Block Core Exchange Program
Also added, I have three H23 blocks that are sleeved and ready to be built or exchanged! $3018.39 fuly built ( details below ) Eagle rods, arias pistons.
Added 100 mm b-series stroker crank available. $850.00 ( custom rods and pistons required )
Fully built, professionally assembled turbo ready race engine bottom ends.
These engines have the same machining, clearances and tolerances as our Team race engines that can produce over 1000 H.P. All meticulously measured, sized, double checked, cleaned and ready to go.
Price for B-series turbo engine builds ( B16, B18A/B and B18C ) $2899.00 !!!!
Price includes the following:
*Block inspection, 100% cleaned and bead blasted to look brand new!
*Golden Eagle Mfg. HD sleeves ( most popular Honda engine sleeve! )
*Arias Pistons ( shelf pistons )
*Eagle Rods ( all with BIG BOLT ARP rod bolts )
*Decking with step deck included ( add $50 for o-ring - optional )
*Bore and Hone ( perfect clearance for smooth, quiet operation and longevity. Our plateau hone requires less break-in for extremely quick ring seal. Tolerances held = Taper .0002", Round .0002" )
*Line bore ( most companies do not offer this because it is too expensive. Crank tunnel is re-aligned to be perfectly straight and withing .0001" on size. )
*Sized crank ( done to obtain PERFECT bearing clearances. We don't just match colors by code, we actually measure and size the crank as needed to our turbo race engine clearances )
*Balanced rotating assembly ( not offered by most other engine builders. Our rotating assemblies are electronically balanced to 10,000 RPM for extremely smooth operation throughout the RPM range )
*ACL race bearings ( coated bearings used in EVERY race engine we assemble )
*New Honda OEM oil pump
*New bottom end gasket set ( oil pan, main seals and oil pickup )
*Fully blueprinted and assembled. You get a spec sheet back with your block dictating the bearing clearances, piston to wall, all product part #'s, etc.
Our prices are a bit more than our competitors, but we do more work and in the long run, we provide more reliability, more H.P. and an overall better engine build.
These engines are sleeved, prepped, measured, machined and assembled by the same people that build motors and do machining for Ed Bergenholtz ( First IMPORT in the 7's ), Lisa Kubo ( First FWD in the 7's ), Sav Leone ( 2002 IDRC Champ ), Gary Gardella ( Fastest unibody IMPORT ), Jason Hunt and many, many more. All work is done IN HOUSE on our equipment, from sleeving, to line boring, all under one roof so tolerances are held to our exact specifications.
CORE EXCHANGE REQUIRED There will be an additional charge is no core is supplied or supplied core is damaged. Core must be same block code as ordered.
Blocks are sleeved and awaiting your special requests. Give us a call (909) 592 - 4311 or send an e-mail to Sales@goldeneaglemfg.com . We are here to serve your every engine need!!
Thanks
Vince Tiaga
Golden Eagle Mfg.
414 Borrego Ct.
San Dimas, CA 91773
(909) 592 - 4311
Old Dec 30, 2004 | 08:39 PM
Whitfield Inc.'s Avatar
Default Re: Golden Eagle Mfg. Sleeved Block Core Exchange Program (GoldenEagleMfg.com)
How about GE scatter shields -
Old Dec 31, 2004 | 05:43 AM
Type-GS-R-Turbo's Avatar
This is awesome. I wish this would've been an option last year.
Old Jan 2, 2005 | 08:44 PM
Default Re: (Type-GS-R-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-GS-R-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">This is awesome. I wish this would've been an option last year.</TD></TR></TABLE>
YEah, it's great for people that need a sleeved block NOW. We have almost every option available
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine &raquo;</TD></TR><TR><TD CLASS="quote">How about GE scatter shields - </TD></TR></TABLE>
I will swing by your shop this week. See you then
Old Jan 13, 2005 | 06:54 AM
Default Re: (GoldenEagleMfg.com)
TTT
Old Jan 14, 2005 | 07:30 PM
Tchleung's Avatar
Hrm..... I have a JDM B18C block no number designation after, Just to be sure, you'll take that as well right? Also, if I send you tyhe block as a core exchange, what has to be all on there? Reason I ask is because the block I ahve only has the BARE block itself with cracked sleeve(cracked about 2" down from the top), and main caps, girdle, main cap bolts. That is it. Would you still take that as a core exchange? or do you need it to be a complete shortblock. Please IM me with what you think or if you would have to charge me additional due to lack of parts and damaged sleeve
Modified by Tchleung at 8:22 AM 1/15/2005
Old Jan 16, 2005 | 12:09 PM
norcalcrx's Avatar
Any pricing on D series?
Old Jan 16, 2005 | 07:16 PM
nvmyb20hatch's Avatar
Default Re: Golden Eagle Mfg. Sleeved Block Core Exchange Program (norcalcrx)
you dont offer anything for a b20?
Old Jan 17, 2005 | 08:39 AM
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Hrm..... I have a JDM B18C block no number designation after, Just to be sure, you'll take that as well right? Also, if I send you tyhe block as a core exchange, what has to be all on there? Reason I ask is because the block I ahve only has the BARE block itself with cracked sleeve(cracked about 2" down from the top), and main caps, girdle, main cap bolts. That is it. Would you still take that as a core exchange? or do you need it to be a complete shortblock. Please IM me with what you think or if you would have to charge me additional due to lack of parts and damaged sleeve
Modified by Tchleung at 8:22 AM 1/15/2005</TD></TR></TABLE>
PM'ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">Any pricing on D series?</TD></TR></TABLE>
D-series is the same price. Do you need the price with or without a core?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch &raquo;</TD></TR><TR><TD CLASS="quote">you dont offer anything for a b20?</TD></TR></TABLE>
Once we have some B20's to do an exchange on, we will have them available. You can always still send in your B20 for sleeving and building!
Old Jan 17, 2005 | 11:08 AM
norcalcrx's Avatar
I have a core to exchange.
Old Jan 17, 2005 | 11:51 AM
Default Re: (norcalcrx)
Sleeving on the d-series with HD sleeves run $850 plus the $350 core exchange that will be refunded when we receive your core. That includes sleeves, installation, decking, cleaning and 100% inspection of the block.
Old Jan 17, 2005 | 02:02 PM
Tchleung's Avatar
Emailed! :D What Bore/CR sizes are available? I'd prolly be interestd in a 84MM B18C 9:1 CR 2 litre baby! (well, almsot 2 ltires )
Old Jan 17, 2005 | 02:46 PM
B18C5NA's Avatar
im looking for a b18c presleeved block 84mm do you have one ready to be shiped ? how much ?and if i dont have a core ? thanks
Old Jan 18, 2005 | 07:11 AM
Default Re: (B18C5NA)
PM'ed
Old Jan 20, 2005 | 01:49 PM
Tchleung's Avatar
No email reply yet?
Old Jan 20, 2005 | 06:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">No email reply yet? </TD></TR></TABLE>
PLease resend your e-mails. We have had a few computer issues the last few days Should be all fixed now
Old Jan 20, 2005 | 08:58 PM
Tchleung's Avatar
OMG that was a lnog email nooooo hahaha.
Old Jan 20, 2005 | 09:12 PM
civhatch21's Avatar
.hey bro how much is it for a sleeved bare block for h22 i have a core exchange sh block as well all i need is the bare block sleeved no internals whatsoever let me know i need a h22a1 block though not the sh model let me know
Old Jan 20, 2005 | 09:27 PM
Tchleung's Avatar
Emailed again
Old Jan 23, 2005 | 11:54 PM
Tchleung's Avatar
Still no replies? what gives. this tiem I saved the email as well incase it jsut isn't gonig through. hahaha
germanegturbo
Apr 19, 2010 07:25 AM
swpdb16
Jan 31, 2008 11:41 AM
SpeedDreamz.com
Mar 26, 2006 07:11 AM
bracket 4 life
Feb 12, 2005 06:49 PM
X-Mazda 3 Racer
Jan 13, 2005 06:53 AM
