zex troubleshooting
Old Jul 21, 2003 | 09:38 PM
xentric_lude91's Avatar
Default zex troubleshooting
I just installed my 65hp shot zex kit on my 91 prelude. I got the kit used, and it had been sitting for aproximatly 6 months. I went to try it for the first time. It ran for about 1 second then i had a HUGE backfire.
i'm trying to figure out what the cause of this is.
did i set my timing incorrectly?
is the NO2 stale?
I'm pretty sure i installed the nozzle correctly... but i guess there's a chance it could have gotten turned when i screwed the hose onto it. It is installed about 6-8 inches from the throttle body. is this to close?
could it have just been an air pocket in the line?
I'd really like to find out the cause before i just go and try it agian.... i don't want to damage anything(obviously)
thanks for the help.
Wade
Old Jul 21, 2003 | 11:09 PM
Broken Gearbox's Avatar
Default Re: zex troubleshooting (xentric_lude91)
did you change your plugs?? i think if your running a 65 you need colder plugs.
Old Jul 23, 2003 | 05:46 PM
Default Re: zex troubleshooting (James.)
yeah, i installed colder plugs.
Old Jul 23, 2003 | 05:51 PM
Burke's Avatar
Banned
did you pull your plugs to see if you had run really lean at all????
Old Jul 23, 2003 | 06:21 PM
oday's Avatar
I had the same happen on my b16a. I installed the zex plugs which are some real pieces. Two of my 4 pugs were fried after my first bottle. well my guess is that you fried a plug and mabe lost a piston because of it. If you are running the zex plugs I would suggest changing to iridium or at least some platinium 4 prong.
Old Jul 23, 2003 | 07:01 PM
Finest's Avatar
Default Re: (oday)
Scary huh? Does it still drive the same? (off the bottle, I mean) If so, it could be that you were running super rich and it combusted in the exhaust piping. Definitely do a compression check to see if you blew something. If all turns out okay, then it's nothing major (I hope?)
hondaeg8
Sep 26, 2004 11:46 PM
GimpyDowns
Sep 27, 2003 06:11 PM
boostincoupe
Jul 20, 2003 05:00 PM
tegtip
May 17, 2003 01:48 PM
wickedxboi
Apr 12, 2002 03:27 PM
