zex nitrous question
Anyone ever have a problem with the nitrous not activating. I have everthing wired up correctly, bottle psi is 950+ on both bottles, the box is program currectly.
With the nos line disconnected, and the car off (ignition on) the system works good @ w.o.t, but when everything is connected with the car running the system fails to activate.
what do guys think this is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -GRIFFIN- »</TD></TR><TR><TD CLASS="quote">dont they read off the tps out put wire ????
check your wiring again
joe griffin</TD></TR></TABLE>
With the nos line disconnected, and the car off (igniton on) the system works good @ w.o.t
everything is wired up correctly.
Hmmm.. this is a ZEX kit you have? It should work fine. Make sure that the source for the arming switch is still good when the car/everything you have running is on.
If you have to, pull the jet, leave the car in neutral, hit wot, and have a buddy see if the light comes on/spray comes out. If the light is not on with the car running/switch armed, it's something electrical. If it does, and no spray comes out, then there's something wrong with the NMU/lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Attaus »</TD></TR><TR><TD CLASS="quote">Hmmm.. this is a ZEX kit you have? It should work fine. Make sure that the source for the arming switch is still good when the car/everything you have running is on.
If you have to, pull the jet, leave the car in neutral, hit wot, and have a buddy see if the light comes on/spray comes out. If the light is not on with the car running/switch armed, it's something electrical. If it does, and no spray comes out, then there's something wrong with the NMU/lines.</TD></TR></TABLE>
I pulled the jet, and tested it with the car off(ignition in the on position) and it works the way it should. Its just that for some reason when the car is running, and I hit it @ w.o.t it doesn't activate.
Curtis2kul
12
Mar 19, 2004 12:24 PM
