ZEX Install Quick Question
Old Oct 8, 2003 | 11:40 AM
Evil DOHC's Avatar
Default ZEX Install Quick Question
Installing a zex kit on a 95 gsr/ls etc, to test at the track tonight Need to know what color wire to tap on the tps sensor. Any ideas? Times will follow tomorrow but for now, I just need a quick answer.
EVIL
GreddySi99's Avatar
Default Re: ZEX Install Quick Question (Evil DOHC)
try the middle wire
Old Oct 8, 2003 | 11:44 AM
TurboLSVtecTeg's Avatar
Im pretty sure its the red wire off the TPS sensor. I might be red/white.
Old Oct 8, 2003 | 11:48 AM
redlinegsr's Avatar
Default Re: ZEX Install Quick Question (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure its the red wire off the TPS sensor. I might be red/white. </TD></TR></TABLE>
Red it is!!!
Old Oct 8, 2003 | 11:56 AM
Evil DOHC's Avatar
Default Re: ZEX Install Quick Question (redlinegsr)
Thanks peoples, I will have a good time to post up tomorrow for everybody. Stock gsr on drag radials with a 55 shot. What are your predictions?
EVIL
Old Oct 9, 2003 | 04:08 AM
I would guess from a 14.2-14.6. Depending on conditions and how good you can drive.
Old Oct 9, 2003 | 04:38 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">I would guess from a 14.2-14.6. Depending on conditions and how good you can drive.</TD></TR></TABLE>
In that case 13.6-13.7
Old Oct 9, 2003 | 04:55 AM
ScrapinSi's Avatar
cut the red wire! cut the red wire! heehehhee
I'd predict low 14's high 13's... I dont recommend spraying out of the hole...
Old Oct 9, 2003 | 05:57 AM
TABIAS's Avatar
I want to be MADE into Ice-T
i've got a 97 ex i/h/e and im wanting to go with a 55 shot, what brand , and what should i change (internals) before i start to use the kit?
Old Oct 9, 2003 | 06:17 AM
HT's Biggest Loser
Default Re: ZEX Install Quick Question (preacherboy)
You dont need to replace internals to spray
bmiller17
22
May 19, 2013 05:54 PM
dohdoh420
Sep 23, 2007 11:00 PM
DC_RaceR
Jul 9, 2007 01:09 PM
Soccerking3000
Jul 31, 2005 06:29 AM
Soccerking3000
Jun 7, 2004 02:22 PM
