Zex Dry Kit
Old Jun 22, 2008 | 07:48 PM
shadhman's Avatar
Default Zex Dry Kit
I have a D16a6 with a compression setup of 11, 6 to 1. Would it be ok if I ran nitrous? I know its pretty high compression but would it be some what safe? Would a tune make it better?
I'm not sure if this is the right forum so if it isnt and you cant provide the answer please point me in the right direction
Old Jun 22, 2008 | 09:13 PM
Tippyman's Avatar
Default Re: Zex Dry Kit (shadhman)
Nitrous LOVES compression. So long as you get a real engine management system and have it tuned properly, I see no problems.
Old Jun 22, 2008 | 10:55 PM
shadhman's Avatar
Default Re: Zex Dry Kit (Tippyman)
What type of engine management system should i look for?
Old Jun 23, 2008 | 01:39 AM
lunatics209's Avatar
is your car an obd1? if so u can take it to a tune shop and get it tuned on crome. they'll use your stock p28 ecu. just ask a tuner he'll tell you wat you need.
Old Jun 23, 2008 | 11:45 AM
shadhman's Avatar
Default Re: Zex Dry Kit (lunatics209)
Sounds good!
Thank you
Old Jun 23, 2008 | 12:15 PM
hondapunkrock's Avatar
with that compressin why not run a zet wet kit, lot safer
but if you got the money, hondata ecu runnin the nitrous is safe and easy and it was a dry shot
shadhman
Jun 22, 2008 08:22 PM
le0ftw
Mar 24, 2007 10:44 PM
Mr Rex
Sep 10, 2006 09:26 AM
D16zex
15
Dec 22, 2005 10:50 AM
hondaeg8
Mar 7, 2005 08:42 AM
