are the zeitronix boost sensor just like a 3bar map sensor?
Old Oct 18, 2005 | 09:48 PM
eg:R's Avatar
Default are the zeitronix boost sensor just like a 3bar map sensor?
as title, confuse with the both, are they both the same thing, boost sensor=mapsensor??
Old Oct 18, 2005 | 10:01 PM
advert's Avatar
Default Re: are the zeitronix boost sensor just like a 3bar map sensor? (eg:R)
i think its just a 3.5 bar map sensor.
Old Oct 19, 2005 | 10:34 PM
eg:R's Avatar
anybody eles know, the zeitronix one is rounded and has 3pin plug
Old Oct 19, 2005 | 10:44 PM
AspectIndustries's Avatar
Default Re: (eg:R)
Its a boost sensor, as in boost gauge. Not Map.
Old Oct 20, 2005 | 01:03 AM
BlueShadow's Avatar
Default Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Its a boost sensor, as in boost gauge. Not Map. </TD></TR></TABLE>
Straight from the Zeitronix website: Boost sensor is a 3.5 Bar absolute MAP sensor. The Zt-2's high resolution boost input in conjunction with a Zeitronix Boost Sensor is more accurate than most boost gauges.
Let's not forget that MAP stands for Manifold Absolute Pressure. The MAP sensor measures the vacuum or pressure in your setup. The Zeitronix uses the same 3.5 BAR Bosch sensor as the AEM MAP sensor kit. Normally the Zeitronix/AEM boost pressure sensor is wired into the datalogging setup so you can log your vacuum/boost. But it can also be wired up to act as the car's MAP sensor. You just have to make sure that your EMS has the ability to run that particular MAP sensor.
pic from AEM site
pic from Zeitronix.com
Old Oct 20, 2005 | 03:15 AM
non-VTEC's Avatar
Default Re: (BlueShadow)
the zeitronix sensor is the same as the AEM boost/map sensor.
im running one as my main map sensor with no problems
Old Oct 20, 2005 | 04:29 AM
DaveF's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the zeitronix sensor is the same as the AEM boost/map sensor.
im running one as my main map sensor with no problems </TD></TR></TABLE>
cost on this sensor??
Old Oct 23, 2005 | 09:14 AM
eg:R's Avatar
thank for all the helpful reply, so can also used this for my ZEITRONIX WIDEBAND to control my boost guage and wire up as my map sensor at the same time??? or i have to buy 2 sensor
Old Oct 23, 2005 | 10:37 AM
non-VTEC's Avatar
Default Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">thank for all the helpful reply, so can also used this for my ZEITRONIX WIDEBAND to control my boost guage and wire up as my map sensor at the same time??? or i have to buy 2 sensor</TD></TR></TABLE>
the boost sensor zeitronix sells you is the same thing as the AEM one.......it works as a MAP sensor. it reads vacuum and boost. it can also be used as the main map sensor for the vehicle as long as you can configure your EMS to read it properly.
you don't need 2 map sensors to make this work.
Old Oct 23, 2005 | 10:43 AM
Boosted Chemist's Avatar
you don't need 2 map sensors to make this work.</TD></TR></TABLE>
what do you just wire it up into the stock harness and just t off the signal wire and run that to the datalogger?
Old Oct 23, 2005 | 01:32 PM
asianspeed's Avatar
Default Re: (Boosted Chemist)
Wow, I didn't know that the boost sensor was also a map sensor. I was looking to upgrade to a 3 bar map, and this would be the ideal solution. Anyone got info how to wire it?
Old Oct 23, 2005 | 01:54 PM
non-VTEC's Avatar
what do you just wire it up into the stock harness and just t off the signal wire and run that to the datalogger?</TD></TR></TABLE>
yes
been running it for about 4 months or more now with no problems........just make sure your EMS is capable of reading a 3.5bar.......im sure it can.....if uberdata can run it anything else can too
H-allmotorda9
Feb 7, 2010 07:29 PM
GoHybrid
Mar 29, 2009 06:13 PM
the.hamburglar
Aug 4, 2007 08:39 AM
B16Drag
Jan 25, 2006 06:59 AM
LsTurbo91
Oct 1, 2003 11:00 PM
