zc/d series manifold
Old Oct 6, 2002 | 10:32 AM
lyleeubanks21's Avatar
Default zc/d series manifold
i have a friend with a 89 crx si, and he wants to turbo it. He would rather turbo a dohc zc motor, and he needs to know if the manifolds are the same. Should he buy the turbo kit first, or the motor first?
Old Oct 6, 2002 | 02:42 PM
speedworks's Avatar
Default Re: zc/d series manifold (lyleeubanks21)
yes, the manifolds are the same with the exception of you have to grind the manifold on the #4 cylinder a little. takes about 5 minutes
Old Oct 6, 2002 | 08:56 PM
skud_dusty's Avatar
Default Re: zc/d series manifold (speedworks)
i'm the friend, and im buying the crx shortly...
so if i bought a turbo kit for a 88-91 crx, put it on, then bought the dohc zc motor, all i'd have to do is pretty much port match the manifold...correct?
thanks for the info by the way. i knew that the 92-95 dseries headers worked with porting, just seeing if the older motor was different
Old Oct 7, 2002 | 02:59 AM
speedworks's Avatar
Default Re: zc/d series manifold (skud_dusty)
no need to portmatch, the ports on the single vs. the zc are the same
Old Oct 7, 2002 | 11:25 AM
skud_dusty's Avatar
thanks for the help, but i think that i've decided to do the whole supra piston, b16 rod combo
jDm bEeZy
11
May 11, 2006 12:20 AM
Darksoul
May 15, 2005 09:07 PM
99sonicbluegsr
Mar 20, 2004 12:19 AM
It's*BOLO!!
Mar 4, 2003 06:33 PM
ucacrx
Oct 5, 2002 05:15 PM
