Your VAFC Hack experiences..........
Old Mar 23, 2003 | 08:46 PM
JDM EG2's Avatar
Default Your VAFC Hack experiences..........
Who ever is doing the hack please post your experience with it and what you think of it. Please post your setup and type of motor.
For my friend so far not so good. We originally were using 390cc dsm from an auto 1g eclipse turbo (did not realize that auto and stick had diff cc injectors) and blew the rings on the #4 piston. All we did was change the block to another b16 block. We have since recentally upgraded to the required 450cc injectors and the settings are -38% across the board wide and narrow throttle as wellas lvt and hvt. Also @ 40psi fuel pressure.
Old Mar 23, 2003 | 09:38 PM
Joseph Davis's Avatar
Default Re: Your VAFC Hack experiences.......... (TurboB16Coupe)
Blew a 30 degree section of #1 ring land in short order. I was running 4-5 psi, which has the ECU reading off the most advanced part of the ignition maps @ approx 34-38 degrees total advance... a NA LS hits about 10 degrees lower at WOT. I think running more boost, which results in less total timing, is safer in these setups... definitely retard your distributor ~3 degrees of so and you only pass through the extreme danger zone briefly.
I now use a chip with ignition maps replotted for the AFC hack, and the car runs great. It makes the ECU behave like a factory forced induction vehicle, as long as you have the AFC to fiddle the MAP sensor signal. One of my friends is running a turbo ZC with a $15 voltage regulator in place of an AFC and the same chip and it runs very well, too.
As far as your friend goes... get an EGT or access to a wideband in short order and tune that fuel - I'm sure it could use with richening in the upper revs as -38% would be a tad lean IMO.
[Modified by J. Davis, 10:49 PM 3/23/2003]
Old Mar 23, 2003 | 11:28 PM
shadowdawn's Avatar
Default Re: Your VAFC Hack experiences.......... (J. Davis)
Stock ECU, Stock b18b, 440cc rc injectors, S-AFC
Settings around -37% average hi and lo
Distributer retarded ~3 degrees, never detonated (audibly)
A/F ratio after tuning is 12.5 or less (cept first gear its about 12.5-12.9 as I saw at the track)
I love everything about it, cept the constant code 13 for baro sensor (its not broken, just a by-product of obd2 + afc hack). People with greddy blue boxes have this problem also when they are obd2 generally speaking.
Deifnalty like this setup 100x more then old stock injectore + inline + 12:1 fmu setup......
Old Mar 24, 2003 | 05:20 AM
GreddySi99's Avatar
Default Re: Your VAFC Hack experiences.......... (shadowdawn)
Just installed mine sunday.
B16a2 stock engine
67,000 miles JRSC 9PSI
Vafc -40% at idle
-34% all the way up untuned
Stock fuel pressure
RC 440's
Runs so so so much better than that Dam SMC
Hopefully to be tuned in the next week or two
I love it so far and the J&S says no detionation what so ever
Old Mar 24, 2003 | 05:28 AM
pbomers's Avatar
is there any way to fix that check engine light on obd2???
Thanks.
PauL
Old Mar 24, 2003 | 05:54 AM
GreddySi99's Avatar
Default Re: Your VAFC Hack experiences.......... (TinyCRX)
I have never gotten a light........YET ??????
Old Mar 24, 2003 | 07:51 AM
shadowdawn's Avatar
Thanks.
PauL
No
Old Mar 24, 2003 | 09:10 AM
leadtrum's Avatar
Default Re: Your VAFC Hack experiences.......... (intercooledJRSC)
you're a lucky bastard then man. i've gotten some weird *** ones but they seem to be happening less frequently lately.
Old Mar 24, 2003 | 09:52 AM
JDM EG2's Avatar
my car is obd1 and on a t3 from a sabb and running 8-10 psi. what are your egt readings.
Old Apr 2, 2003 | 10:19 PM
M-EJ1's Avatar
I'm running the VAFC hack with about 6 psi on a greddy SOHC kit (D16Z6) with DSM 450's. I'm retarding about 3 degrees, maybe a little more, my timing gun doesn't give me a readout like the fancy ones.
Anyway, I started with -40% across the board and the car idled like **** and detonated like **** on the top end. So, to fix the idle, I richened it to -30% below 1000rpm's and it idles much better now. The detonation up top is another story. I'm retarded about 3 degrees like I said before, and I went ahead and richened it up a ton up top (-38 starting right before the VTEC crossover and continuing to -34 at 8000 rpm), and I'm still detonating once I hit about 4500 under load. It's pissing me off. Maybe I need to take more timing out, or just suck it up and buy a 6btm.
My other beef is the bucking at part throttle... gets annoying trying to drive in a parking lot. Also, the hard starts kind of suck too.
Maybe all this will be fixed with tuning I don't know.
J.Davis: where did you get your chip that remaps the timing for the AFC hack? Are you fairly happy with it?
[Modified by M-EJ1, 11:21 PM 4/2/2003]
Old Apr 3, 2003 | 12:55 AM
turb's Avatar
Default Re: Your VAFC Hack experiences.......... (M-EJ1)
j. davis,
are you using the uberchip with your afc hack?
Old Apr 3, 2003 | 05:59 AM
M.A.R.C.'s Avatar
Default Re: Your VAFC Hack experiences.......... (leadtrum)
i love the afc hack been fine for 6 months now... yah that pesky code 13 is rare for me nowadays
Old Apr 3, 2003 | 06:02 AM
leadtrum's Avatar
Default Re: Your VAFC Hack experiences.......... (CivicRyda2k)
yea that's the one i get too, pisses me off cause it just happens at random for some reason.
Old Apr 3, 2003 | 06:35 AM
rbf351's Avatar
i'm been running th hack for a few months now, no problem at all.
i actually just had it tuned 2 weeks ago
later when i get home i'll copy down the exact setting that i have and post them
cause they are no where near -35 they are mostly at -18 or so
here is my dyno sheet from tuning
my setup is the following
2000 Civic Si
bone stock engine except for gsr cams
revhard stage 2 kit @9-10 PSI
AFC hack
DSM injectors
AEM FPR
walbro high flow fuel pump
[Modified by rbf351, 10:36 AM 4/3/2003]
Old Apr 3, 2003 | 06:49 AM
Tony Starks's Avatar
Default Re: Your VAFC Hack experiences.......... (rbf351)
D16Y8 at 8 psi on a T3
450cc w/ intank walbro
Setting start at -43 up to -35
I HATE THE BUCK. You know, when you let off the gas and get back on it. DRIVES ME CRAZY!
Old Apr 3, 2003 | 07:14 AM
lsvtec101's Avatar
havin a little prob with the vafc hack.. when i hit like 1500rpms she wants to hesitate..... heres a video
members.***.net/cjf02917/afchack.AVI
Old Apr 3, 2003 | 07:21 AM
Default Re: Your VAFC Hack experiences.......... (aemcivic_02917)
Nice spot for the VAFC. Thats where I put mine too.
Old Apr 3, 2003 | 07:37 AM
LshatchTurbo's Avatar
New User
Is the AFC hooked up right?
Old Apr 3, 2003 | 07:50 AM
lsvtec101's Avatar
Default Re: Your VAFC Hack experiences.......... (lshatchturbo)
yes the vafc is hooked up right.. car runs great except that hesitation at 1500rpms
edit: i dont have my two 02 sensors hooked up and my air temp sensor isnt hooked up yet..... still dont explain why 1500rpm
[Modified by aemcivic_02917, 8:52 AM 4/3/2003]
Old Apr 3, 2003 | 08:01 AM
rbf351's Avatar
2nd O2 sensor won't do anything except tell u your cat isn't there or ins't working right
Old Apr 3, 2003 | 08:14 AM
lsvtec101's Avatar
im guessing this is normal with the vafc hack? its called "part throttle bucking" is there anyway to get rid of it
edit: would safe mode make it do this.....aaaaaaaaaaaahhh **headacke**888
[Modified by aemcivic_02917, 9:36 AM 4/3/2003]
Old Apr 3, 2003 | 10:00 AM
I made the chip myself. I love it; I have limited standalone functionality out of the setup at the cost of a $75 chip burner, chips/sockets, and some freeware tuner apps courtesy of PGMFI.
I had to do my first chips by editing the maps in a hex editor, by hand. That was pretty ******* unpleasant, I think I spent 4-5 hours on the ignition map alone. With the advent of Ghettodyne, etc, I spend the majority of my time implementing changes in tune by swapping the chip from ECU to burner, just like the Hondata guys had to until recently.
I've got a GM 2 bar Speed PHreak kicked me, and the tune for it, ready to roll. Just waiting on a few last minute parts to reassemble the vehicle and I can report back.
Old Apr 3, 2003 | 10:04 AM
lsvtec101's Avatar
yo peeps anyone ever have hesitation @1500rpms???? how do i fix this, ive tried adjusting the fuel settings and timing, still nothing..
Old Apr 3, 2003 | 10:08 AM
Do you have your idle bogged down with a lot of fuel? Every time I had mine set to -25% at 1000 rpm I got a sluggish/bogged takeoff on tip in.
Old Apr 3, 2003 | 10:31 AM
lsvtec101's Avatar
im running the vafc w/ RC440 's w/ walboro fuel pump and i have it set for -40% across
