Your thoughts on this setup??? MF2
Old Dec 18, 2001 | 01:22 AM
turbocoupe's Avatar
Default Your thoughts on this setup?? MF2
D16Y, Greddy turbo, and a MF2 setup. . .with 440's
I don't want to hear "swap for a DOHC" I want to know if anyone has done it or if it's not worth it. . . and no I didn't do a search.
I'm arguing with Art. . .and Art you can't reply to this thread!
Old Dec 18, 2001 | 06:15 AM
VTC_CiViC's Avatar
Default Re: Your thoughts on this setup. . . (turbocoupe)
Me Me! Well, no MF2 though. With a set of 440's, there no way on this earth you're gonna need an additional injector setup, I use 440's in my D16 now and it's SUPER rich even with -40% AFC trim. Ditch the MF2, stick with the 440's. It'll take a bit of playing with to operate just right (or as close as you can get w/o a standlone), but it's fun when you're done
Old Dec 18, 2001 | 06:24 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Your thoughts on this setup. . . (VTC_CiViC)
MF2 Blows.
Old Dec 18, 2001 | 06:27 AM
D-Man's Avatar
Default Re: Your thoughts on this setup. . . (ForcedAccord)
id skip the greddy turbo and use a T3/04 hybrid Turbo
Old Dec 18, 2001 | 06:36 AM
chri5's Avatar
Default Re: Your thoughts on this setup. . . (D-Man)
Like VTC said, with the 440s you wont need the MF2.
VTC:If you lower the FP a little bit you wont be as rich at idle.
Old Dec 18, 2001 | 07:32 AM
VTC_CiViC's Avatar
Default Re: Your thoughts on this setup. . . (Strng1dah)
Working on obtaining an adjustable FPR as we speak
Old Dec 18, 2001 | 12:52 PM
greyzone's Avatar
Two questions first:
1) How much boost you plan on running and/or want to be able to run in the future?
2) What type of WHP you shooting for?
Old Dec 18, 2001 | 10:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Your thoughts on this setup. . . (greyzone)
Anymore thoughts on this? Im kinda curious how people feel about IAC. Personaly Im not a fan, but it does have some good points. I just would like to see what others views are on it...
art
Old Dec 19, 2001 | 04:58 AM
BlueShadow's Avatar
Default Re: Your thoughts on this setup. . . (Arturbo)
art
Personally I didn't like the MF2... until I found out that it can adjust fuel by RPM and BOOST (3D fuel adjusment). I still don't like the idea of putting 2 injectors in the intake, cause if the injectors are not placed properly, you could have problems.
If you dont like the idea of the additional injectors in the intake, you can look into fabricating an additional fuel rail. With this type if setup you can position 1 injector for each cylinder for a total of 4 additional injectors. I think DirtyLude and PureLude were working on a setup like this, but they decided to go full standalone instead. Below is a link that has some info on the 4 additional injectors, scroll down to 3/4 of the page to the date : 01/02/2001.
Courtesy of DirtyLude's site: http://www.hondaprelude.to/articles/inst_turbo.html
Old Dec 19, 2001 | 09:32 AM
turbocoupe's Avatar
Default Re: Your thoughts on this setup. . . (BlueShadow)
Thanks guys. . .I guess you were right Art. . .
Hondata is too much of a pain in the ***. . .I'd need to get a different ECU and harness. . .about $300 on partstrader. . .but yall know how that **** goes.
VFAC and 440's might be the route I'll go. . .
GREYZONE--I would like to hit 200+ at the wheels at 13 psi.
Marc
[Modified by turbocoupe, 12:33 PM 12/19/2001]
Old Dec 19, 2001 | 11:19 AM
greyzone's Avatar
Marc
You can get damn close to that going this route:
–96 EX Coupe 5spd
–1.6L SOHC VTEC D16Y8
–GReddy Turbo w/Blue Box
–GReddy Type S BOV
–GReddy T-31 Intercooler
–GReddy Boost Controller, Profec-B
–GReddy EVO Exhaust
–Holly 255lph in-tank Fuel Pump
–Vortech 10:1 FMU
–A’PEXi V-AFC
–MSD SCI Ignition
–MSD Blaster 3 Coil
–MSD Pro Cap
–MSD Plug Wires
–NuForms Block Guard
–2 Mil Head Gasket (GReddy, of course)
–ARP Head Studs
This is 210whp at 12psi...
Also, If you go with the injectors consider 310s over 440s, 310s shoudl be more than enough, but give you better performance at idle and freeway cruising...I'm still using stiock injectors and they're working fine. Kinda like if it works, don fix it.
I'm also gonna be going to 8:1 on the FMU, and Im still rich at 12lbs, even with the stock injectors and intank pump. Although, if over 90psi is needed you'll have to go with an inline pump.
Thing is, with 13psi, you're starting to really hit the "cross-over" point with this engine where the above setup has its limitations and it becomes time for rods, pistons and sleeving.
Old Dec 19, 2001 | 01:48 PM
Arturbo's Avatar
Better than steak
25 Year Member
I never said Hondata was a pain in the ***. I prefer hondata rather than the alfabit soup FMU/ AFC/ VFAC/RC combo.
art
Old Dec 19, 2001 | 03:24 PM
jinxproof99's Avatar
New User
i am running an 8 injector set up on my new set up. two fuel rails. but thats with a stand alone.
Old Dec 19, 2001 | 05:18 PM
greyzone's Avatar
Default Re: Your thoughts on this setup. . . (jinxproof99)
Yo Art, you dissing my alphabet soup?
[Modified by greyzone, 6:19 PM 12/19/2001]
Old Dec 19, 2001 | 06:03 PM
Arturbo's Avatar
Better than steak
25 Year Member
No, because I also use the FMU. But you have to understand that the FMU is old 70's turbo technology. Now we have better options to choose from. Nothing wrong with alphabet soup, just not my choice.
art
Old Dec 19, 2001 | 09:56 PM
greyzone's Avatar
Got any suggestions for me on a better way to run my setup? (see above)
let me know, cause I wanna keep learning about options and better ways of doing it.
[Modified by greyzone, 10:56 PM 12/19/2001]
Old Dec 20, 2001 | 09:05 AM
VTC_CiViC's Avatar
440's and AFC work for me, plus after my build up this summer, I can keep my 440's with either Hondata or AEM
Old Dec 20, 2001 | 10:15 AM
turbocoupe's Avatar
Art I didn't say you said the Hondata was a pain in the ***. . .it just seems like a pain in the *** to me. . .ya know splice here, soder there. . .blah blah blah. . .I'll probally end up going alphabet soup though. . .the coolness factor with the VAFC on your console gives me wood.
Greyzone I pretty much have the same set up as you except for all the MSD ignition ****. . and the blockguard and studs. . .
[Modified by turbocoupe, 1:17 PM 12/20/2001]
Old Dec 20, 2001 | 02:56 PM
greyzone's Avatar
Those are some major factors (needed) for higher boost, also the 2 mil headgasket.
How are you running at idle and regular non-boost driving, like city and freeway?? Whats your fuel delivery system, ie: fuel pump, FMU, max fuel pressure (idle to max boost), etc...Also, why'd you go 440s over 310s or 370s??...
[Modified by greyzone, 3:57 PM 12/20/2001]
Old Dec 20, 2001 | 03:05 PM
VTC_CiViC's Avatar
Walbro/BBK 255lph pump, RC440's, AFC trim. Car drive just fine off boost thanks to the AFC trim. Haven't had a chance to test pressures though which I need to do cause I wanna pick up an adjustable regulator and dial back a little fuel at idle, work with a slightly lower pressure overall. I choose 440's because Ive always intended on building the motor up and going with lots of boost in the future, may as well the big ones now.
[Modified by VTC_CiViC, 7:05 PM 12/20/2001]
Old Dec 20, 2001 | 09:48 PM
greyzone's Avatar
so no FMU or FPR?? How much boost and whats your AF running at max boost, do you know?
[Modified by greyzone, 10:50 PM 12/20/2001]
AR_96
Aug 28, 2009 10:08 AM
1996ex
Sep 5, 2006 05:07 PM
GX
Jan 5, 2004 12:48 PM
