Your thoughts on H22 Boosted......
Old Jul 28, 2009 | 02:50 PM
Bwhit12's Avatar
Default Your thoughts on H22 Boosted......
Getting ready to put a H22 into my EG hatch shell and I am looking to boost it as quick as possible. I don't know to much about boosting so it would be great to get some input from some people that have boosted or know a lot about boosting. I know I will have to change internals after so much boost, but what parts do you reccomend and what other parts should I change to help performance? Or if you could point me to a website that could help me out that would be great.
Thanks
Old Jul 28, 2009 | 03:35 PM
malink's Avatar
Default Re: Your thoughts on H22 Boosted......
search fonction
k thx
Old Jul 28, 2009 | 04:06 PM
Bwhit12's Avatar
Yea I tried the search fonction and did not find any info.....
Old Jul 28, 2009 | 04:16 PM
Garage 808 Hatch's Avatar
we made 330+whp stock H22 in an accord 4 door, lasted over 3 years of abusive driving from the owner. its all in the tune
Old Jul 28, 2009 | 05:10 PM
Bwhit12's Avatar
That sounds nice, but I am looking for mine to last a little longer than three years. Do you have any suggestions on parts to use?
Old Jul 28, 2009 | 07:05 PM
malink's Avatar
ok pretty boy,
h22 have frm sleeves and you can only run 2 types of forge pistons : mahles and juns
you could sleeve the block an run cp, wiseco, je pistons and throw a set of eagle rods and redo the bottom end. On top of that, you need a turbo kit that will last you long. ebay is out of the answer and I consider you look at peakboost, AFI, spoolin but you will also need a fuel pump, injectors, engine management plus tuning. If you want to be on the safe side, upgrade the brakes and suspension to support your mods. A new clutch to hold all that power
Do you get my point?
I hope you have a nice budget
I made 340 whp on a stock h22 with water/meth and I was running 280 whp with no injection kit till I sold the car
Old Jul 28, 2009 | 07:43 PM
1fastlude1's Avatar
do alot of research and have some money saved for a motor, yes you can boost a stock h22 but you need a very good tune it is really all in the tune. but the frm sleeves suck and the h22/h23 ring glands suck the mahle pistons are very good i used them till i sleeved my block and even after i bought the sleeved version from mahle because i was very satisfied but if you plan on having a dependable boosted h22 save some money build it then boost just my opionen after alot of money ive spent on mine and good luck
Old Jul 29, 2009 | 03:15 AM
Bwhit12's Avatar
Thanks for the info guys and Malink you answered my question just like I needed.
Old Jul 29, 2009 | 06:28 AM
malink's Avatar
your welcome
and dont forget to change your hydrolic tensionner to the h23 manual tensionner. Ive learned the hard way
Old Jul 29, 2009 | 06:31 AM
malink's Avatar
the frm sleeves are one of the strongest but the real problem is the ringland on the pistons. I would recommed to do a leakdown test and compression if you want to stay stock to see if your motor will handle it. If everything workouts fine, you can start looking at turbo kit but please make sure you pay for a reputable tuner
Old Jul 29, 2009 | 07:16 AM
Bwhit12's Avatar
I don't want to stay stock. I know you are able to stay stock as long as you run low psi, but I want to run a little higher psi and I want to be safe. Thanks for the info.
Old Jul 29, 2009 | 07:23 AM
malink's Avatar
well then get your block sleeves and while your there, redo the bottom end
you wont regret it
Old Jul 29, 2009 | 09:56 AM
Bwhit12's Avatar
Isn't there another way to protect your motor without sleeving it? I forget what its called.
Old Jul 29, 2009 | 10:12 AM
malink's Avatar
maybe your talking about a blockguard but the h22 are closedeck. Ive heard about dartons liners but you might has well just sleeve it.
For the h22 its liners or sleeve, mahles and jun pistons with stock sleeves
Old Jul 29, 2009 | 10:28 AM
Bwhit12's Avatar
That is what it was called. Only problem is that I know of zero shops in Ohio that will sleeve.
hondaapi's Avatar
@bwhite12
Where do you come from?
You seem to be newbie, so why don´t you stay on stock internals and so on. For the first try on F/I it is better to blow a stock engine than a build or sleeved engine.
That an engine is buildt or sleeved does not mean it is impossible to destroy/demage it ...
Just my opinion.
Old Jul 29, 2009 | 10:35 AM
Bwhit12's Avatar
I'm from Cincy, Ohio.
Old Jul 29, 2009 | 10:47 AM
J.Berta's Avatar
ship to Golden Eagle. they do a great job! call and talk to Robert.
Old Jul 29, 2009 | 11:00 AM
malink's Avatar
I'll give you my personal opinion.
Leave your engine stock for now. You should get theses:
-fuel pump
-injectors
-engine management
-exhaust (3 inches)
-clutch and flywheel or resurface yours
-a good turbo kit has I mentionned in the previous post
-good rad with spal fan/shroud
now heres the advice...put on the kit and tune it and run it till it break (if it does) and then buid the bottom end. If you do this all at once...you can easily spend over 8k. Now be wise and spend 5k and run for the summer and next year build it if your have a problem. If you decide to follow my advice, I would consider buying a water/meth injection kit.
Old Jul 29, 2009 | 11:12 AM
Bwhit12's Avatar
So you don't think that I should at least block guard and engine management would include rods and pistons and any other internals.
Old Jul 29, 2009 | 11:15 AM
malink's Avatar
you cannot run a blockguard in a h22...closedeck
and no enginement management doesnt equal pistons and rods...its the ecu
Look buddy, I dont want to be a dick but you dont know **** and what will happen if you have a problem with your set up? I wouldnt want to turbo my car if I dont even know the basic...
leave it stock for now and start reading
Old Jul 29, 2009 | 11:24 AM
Bwhit12's Avatar
Alrighty then... I planned on reading more once I get time. Any good web pages that have good detailed information?
Old Jul 29, 2009 | 11:25 AM
malink's Avatar
your on it..lol
Old Jul 29, 2009 | 12:24 PM
viper_boy403's Avatar
Not all H22's are closed deck, buddy
Old Jul 29, 2009 | 03:46 PM
malink's Avatar
i know but the majority of them are and a block guard is pretty useless IMO
