your coolant setup
Old Jul 24, 2008 | 04:04 AM
Dave_yd's Avatar
Default your coolant setup
I see alot of posts on here about peoples cars overheating etc, im wondering what setups work and what i'll need for my car, so will people list:
car:
Engne + Power+ turbo:
Coolant setup:
cheers
Dave
Old Jul 25, 2008 | 03:13 AM
DreTec's Avatar
I'm building up my turbo setup at the minute,
I've been advised to do the following:
Get an Ali-rad or a full size oem ITR rad (bigger)
Get a racing thermostat (opens up earlier)
Put the fan on a switch (so it not only comes on when it's told to, but you can control it to come on early yourself) Also BuddyClub do a switch that bring the fan on early!
And most importantly, make sure you fill up the coolant properly, only use Honda OEM coolant with deionised water (if not already pre-mixed) and make sure you let all the air get out of the system!
All of the above i'm sure would help you avoid ever encountering overheating!
Old Jul 26, 2008 | 09:51 PM
blinx9900's Avatar
Default Re: (DreTec)
car: 96 civic
Engne: B16b/a 333whp GT3076R ram horn mani.
Coolant setup:Half size aluminum radiator, 11" spal 5blade fan (i wish i got the 12") with buddy club fan switch, 2 holes drilled in type r thermostat. premix fluid only!
my car runs a tad on the hot side but not enough that i have to worry, if i had the 12" fan i think it would have been better, my tuner likes to add a lot of timing so that could be why...
Old Jul 26, 2008 | 10:01 PM
Muckman's Avatar
Moderator in Chief
Default Re: your coolant setup (Dave_yd)
Car: 2000 Integra GSR
Engine: built and sleeved B18C1, GT3076R-13, Hytech Manifold = 425hp
Coolant: Custom 3/4 width aluminum dual pass radiator, -16 coolant lines, 1.35bar rad cap, OEM thermostat, two 12" pusher slim fans.
https://honda-tech.com/zerothread?id=2346412
No coolant problems but I do seem to have very high engine bay temps due to lack of air flow so Im actualy surprised the rad can keep up. Its awesome!
wmac547
Honda CR-V & Element
Apr 18, 2019 10:20 PM
Akai Star
Apr 14, 2010 05:29 PM
vlude99
Jul 30, 2009 05:58 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
