Ya think I've ported this enough?
Old Oct 5, 2002 | 05:30 PM
Hammer_head's Avatar
Default Ya think I've ported this enough?
This is my wastegate housing and my O2 housing. I have a full 3" turbo-back exhaust and I had crazy boost creep above 5200 rpm before I dropped a valve. You think this might be enough porting?
[Modified by Hammer, 8:33 PM 10/5/2002]
Old Oct 5, 2002 | 07:59 PM
D-Man's Avatar
Default Re: Ya think I've ported this enough? (Hammer)
man,that port job dont look to good looks all egg shape and i dont think itll cure your boost creep problem because the wastegate door is still the same size so it can only let so much exhaust pass thru it before it starts backing up.
Old Oct 5, 2002 | 08:03 PM
filetofit
Guest
Posts: n/a
Geez, how many grinding bits you go through?
Old Oct 5, 2002 | 08:28 PM
Vanilla Ic3's Avatar
Airflow is pretty damn complicated. Saying it wont work well just because it is not perfectly round is a bit arrogant. Run it and see if it helped.. not like it cost you a lot of money to do.
Old Oct 5, 2002 | 08:44 PM
D-Man's Avatar
Default Re: Ya think I've ported this enough? (Vanilla Ic3)
who said that was the reason it wont work well,not me....if you think so,try reading my post again,this time,all of it.
Old Oct 6, 2002 | 11:58 AM
Default Re: Ya think I've ported this enough? (D-Man)
If you notice: I can only go so far down or I run into the turbo exhaust port. there is no need to go up because of the way the flapper opens. So I concentrated on the bottom half of the bowl and to each side.
Here is what I mean:
Old Oct 6, 2002 | 12:02 PM
Default Re: Ya think I've ported this enough? (filetofit)
Still using the same one. I got a solid carbide bit from MAC Tools. Lifetime warranty. $40. Not too shabby. I also got a HD air die grinder from them too. 25,000rpm.
Old Oct 6, 2002 | 12:03 PM
Here is a view of the stock one:
Old Oct 6, 2002 | 01:31 PM
boosted3g's Avatar
i think its a good idea and will work well. Most of the time the best performance parts are fabricated not bought. I almost refuse to buy anything anymore since i learned how to weld a few years ago. I give you props and hope it does the trick.
Old Oct 7, 2002 | 09:04 AM
Default Re: Ya think I've ported this enough? (boosted3g)
Ditto here. I bet it will help. Just because the flapper valve is still the same size doesn't mean your mod wont do anything. Ignore the egg-heads.
Old Oct 7, 2002 | 11:10 AM
turbosol's Avatar
I think you need to consentrate on the O2 sensor housing, you can also port the wastegate hole a little.
Old Oct 7, 2002 | 11:44 AM
Overblown-Teg's Avatar
Default Re: Ya think I've ported this enough? (turbosol)
Hammer- shortly I will have a big o2 housing replacement for the dsm cars.. It should work for yours as well. If you want shoot me an email and I can let you know when its all ready. I should have it in a couple weeks. I plan to make it fit a 3" downpipe. oops looks like you do have a dsm..
[Modified by Overblown-Teg, 8:45 PM 10/7/2002]
Boostage
Jan 21, 2009 07:41 AM
D-meet07
May 25, 2007 09:30 PM
gsrt
Oct 16, 2006 11:24 PM
RACEPAK
Mar 3, 2005 12:11 PM
BoostedsiR
Mar 17, 2004 10:59 AM
