WTF piston/rod help
Old May 19, 2005 | 04:39 PM
SOHCD16y8's Avatar
Default WTF piston/rod help
Hey, im in the middle of building my bottom end right now and when i put my rods into the piston the side clearance is much larger than stock. I have SRP 81.5 mm 9.2:1 compress and eagle rods in a 94 b18b1. The rods are the same size as stock but the pistons are a lil wider. I check both parts with the companies and I have the right parts. Is this ok? does anyone have any experience with this?
Old May 19, 2005 | 04:47 PM
SOHCD16y8's Avatar
pistons part number is SRP-149219
Old May 19, 2005 | 05:37 PM
LVB18Civic's Avatar
Default Re: WTF piston/rod help (SOHCD16y8)
The piston should be larger than stock. You bought 81.5mm pistons. You need to bore and hone your cylinders.
Old May 19, 2005 | 07:11 PM
SOHCD16y8's Avatar
I worded that wrong, what i mean is that the rod-piston clearance is not the same as stock(the space between the rod and the inside of the skirt were the wrist pin is)
Old May 19, 2005 | 08:04 PM
KillerBee18's Avatar
Default Re: (SOHCD16y8)
I doesnt matter your rod should not be moving side to side anyways unless you want to have a serious case of crank walk.
Old May 20, 2005 | 05:38 PM
SOHCD16y8's Avatar
thats what i was thinking but the sheet the pistons came with said to check that. I was just double checking. Thanks
Old May 20, 2005 | 10:34 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking but the sheet the pistons came with said to check that. I was just double checking. Thanks</TD></TR></TABLE>I don't think that was the clearance they were talking about.
Yuleluder
Feb 15, 2006 05:14 AM
Novtecdohc
Jan 20, 2006 02:26 PM
jakscivic
Jan 13, 2006 02:48 PM
CRX Lee
Feb 9, 2004 08:39 AM
Project_SOHC_EX
Jun 3, 2003 02:47 PM
