wtf is this
http://www.youtube.com/watch?v=3Mp0JtmCLi8
This guy is claiming hes making 550WHP on 15PSI on a GT30. My friend is trying to tell him how this isn't even possible and he's saying that my friend doesn't know what hes saying.
Please enlighten me if this really is possible, because I think this guy is full of it.
And assuming that the guy who says @ 3bar actually means 29PSI, it still means that this guy is flowing about 25lb/min of air. Making it impossible for him to be making 550WHP on 25lb/min of air.
ya we did. 560HP (not WHP) is max output for the turbo he says he has. And according to this other forum a T61 can flow 50lb/min @ 3bar. So considering hes running 1.1bar...
Just cool out.. slow down.. start understanding the physics and the math behind what we're saying about these airflow pressurization numbers.
At 3bar, a SC61 (with either the 72mm or 74mm turbine wheel) is doing WAY more than 50lbs/min. I think you gotta start understanding what these calculations mean before you start spouting them off like that. Be it you, or your friend. None of this...the way you're describing it, is making ANY sense.
35r that makes it a lot different.
Either way he's at 15 psi and claiming 550whp. Which seems pretty far fetched even for a gt35
seems similar to my old car ~15psi 475whp. with a gt3076r. just ask him what the car traps at the track if hes gone, that will easily tell you the truth.
http://www.youtube.com/watch?v=-EpOk8GCnjM
I put a gt30 on a 2.0l stroked gsr(I know, I know) and at 18psi it made 498hp and was brought down to 15psi making 475hp. Haven't seen the car since and I don't think he ever tracked the car so I can't tell you any times. He was more interested in road course.
I "know" the guy. It is a boy here in Germany who believes to be god of tuning and as far as I know the car (in this cobfiguration) never met a a real dyno.
He and some of the guys around hin "measure" theire cars with Iphones and are saying number just to compare the lenght of ..... well, you know.
But people believe everything ... people believe what they want to believe :-)
Don't you guys know? If it's on youtube, IT MUST BE TRUE! lol
He's from Germany. He's probably using an imported dynocom setup incorrectly. My guess is someone wanted it to display WHP calculated from NM's but input the conversion wrong, or the output was kilowatts and his hand math is terrible.
Or he's just padding his numbers thinking nobody's ever made that much power in a Civic before.
