are AN wrenches really needed for AN fittings?
Old Dec 12, 2006 | 01:55 PM
Mikey3000's Avatar
Default are AN wrenches really needed for AN fittings?
just wondering if i really need to spend money on AN wrenches for AN (earl's, russell, etc) fittings. do regular open ended wrenches round the edges?
Old Dec 12, 2006 | 01:57 PM
speedworks's Avatar
Default Re: are AN wrenches really needed for AN fittings? (Mikey3000)
the wrenches are made from aluminum so as not to mark-up the fittings. you can use whatever though.
Old Dec 12, 2006 | 02:01 PM
N20civicB18's Avatar
Default Re: are AN wrenches really needed for AN fittings? (speedworks)
ive never used them but always plan on buying a set.
Old Dec 12, 2006 | 02:07 PM
a1320addict's Avatar
Default Re: are AN wrenches really needed for AN fittings? (N20civicB18)
Little electrical tape arund an adjustable wrench should do the trick, I do plan on picking up the set from Summit though.
Old Dec 12, 2006 | 02:16 PM
ebydrc's Avatar
Banned
plus one i just put tape on the wrench
david
Old Dec 12, 2006 | 02:17 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">just wondering if i really need to spend money on AN wrenches for AN (earl's, russell, etc) fittings. do regular open ended wrenches round the edges?</TD></TR></TABLE>
i use whatever makes it turn.. from regular to locking wrenches, cheap adjustable wrenches always come loose as you apply more force.
Old Dec 12, 2006 | 02:21 PM
Dee's Avatar
Dee
Default Re: are AN wrenches really needed for AN fittings? (vtec.dc2)
When I install the hose ends I always install the rubber guards on the vice and wrap the adjustable wrench with tape. On the motor/vehicle I use dual adjustable wrenches wrapped in tape.
Old Dec 12, 2006 | 02:31 PM
CRXDrew's Avatar
Electrical tape on the fitting.
If I cared.
Old Dec 12, 2006 | 02:42 PM
Mikey3000's Avatar
Default Re: (CRXDrew)
very nice
Old Dec 12, 2006 | 03:20 PM
ExospeedAMcrx's Avatar
Default Re: (Mikey3000)
If you are going to be using AN fittings on your car, its good to invest in the wrenches. You dont want to mess up the look of the fittings in the long run.
Old Dec 12, 2006 | 04:01 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (exospeedAMcrx)
i use knipex pliers... flat jawed aluminum pliers that are adjustable. never had a problem
Old Dec 12, 2006 | 07:41 PM
vaporboy12's Avatar
Default Re: (wantboost)
i just use adjustable wrenchs works like a charm
Old Dec 12, 2006 | 10:36 PM
djphonics's Avatar
Default Re: (vaporboy12)
+1 tape on the Mexican socket set.
Old Dec 12, 2006 | 11:28 PM
ProjectDarkBlack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to be using AN fittings on your car, its good to invest in the wrenches. You dont want to mess up the look of the fittings in the long run.</TD></TR></TABLE>
Or if you don't care and have redone your oil drain 3 times in two weeks you just go commando and scratch the **** out of em
Old Dec 13, 2006 | 03:06 AM
Finland's Avatar
I have a set, they are fantastic, and they really save the anodized finish on the fittings.
Old Dec 16, 2006 | 03:46 AM
deryck324's Avatar
adjustable wrenchs with electrical tape on them ftw
Old Dec 16, 2006 | 04:10 AM
string's Avatar
Default Re: (deryck324)
My braided lines are there for function not form; so I use a normal spanner like a real man
Old Dec 17, 2006 | 09:41 AM
akira712's Avatar
just a couple all/16ths wrenches and some electrical tape here
vtec_lude
Welding / Fabrication
16
Sep 13, 2007 10:28 PM
marcusgnf
Apr 5, 2006 06:53 AM
PhatBoy5015
Feb 26, 2006 03:48 PM
ITB
Dec 1, 2005 10:08 PM
.water
24
Nov 8, 2005 08:50 PM
