Teflon Tape on tapered fittings?
Re: Teflon Tape on tapered fittings? (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage »</TD></TR><TR><TD CLASS="quote">I did and i don't leak at all</TD></TR></TABLE>same here. works when you dont have the same degree flare on both fittings. if they are the same degree, then dont worry about teflon
Re: Teflon Tape on tapered fittings? (KimchiBoyTypeR)
they are tapered for a reason, they dont need anything but the 37* flare to seat. its actually a rellay good way of sealing without having to add anything to it
Re: Teflon Tape on tapered fittings? (Hondaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict »</TD></TR><TR><TD CLASS="quote">LOL, DON'T put tape on a tapered fitting. It seals on the taper, NOT on the thread! </TD></TR></TABLE>
yup
ive been using solid copper feed line's for 3 years now with no problems w/ taper fittings. You dont use anything on them. I also use them at work on many things in HVAC.
yup
Re: (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 »</TD></TR><TR><TD CLASS="quote">i use liquid teflon on my fittings, just for that extra reassurance.
Me too. Except for the -an sides (taper).
Re: (v4lu3s)
lol yeah i had a guy here that said to put teflon on the taper side on the thread, im like, lol if the taper leaks its going to leak out of the line before it could get to the threads since the threads pulls the taper onto the fitting.
Mr. Badwrench
yeah.
yeah.
AzntaggeR
10-02-2004 04:45 AM
