would this be a good set up?
Old Jun 26, 2003 | 09:39 PM
Chiclets's Avatar
Default would this be a good set up?
i have a b16 in a 93 dx hach with crower stage 2 valvetrain and a stock bottom end and i'm planning on going turbo with a drag 3 turbo kit the kit includes
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T3/TO4e High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
BLITZ Super Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
also I have an str fuel rail, str 70mm tb, 310cc rc injectors, jg intake manifold, and hondata
I just want some imput to see if this a good set up for my car
( I mostly drag race with my car and would like to run 11. sec in the 1/4
Old Jun 26, 2003 | 09:43 PM
bluebullet's Avatar
Default Re: would this be a good set up? (bluedemon)
lose the deltagate go with Tial or Turbosmart wastegate
Tinberland21
Northeast (Sales)
17
Apr 7, 2008 08:37 AM
Tinberland21
Apr 6, 2008 06:19 PM
sir00
Feb 26, 2006 03:28 PM
G_moneydc2
Sep 6, 2005 11:18 AM
Fink2iCe
Aug 11, 2004 12:36 PM
