Would this be an air pocket in my system?
Old Oct 16, 2003 | 08:05 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Would this be an air pocket in my system?
I've been noticing my temp gauge going up sometimes when I'm at a light. It doesn't do it all the time just sometimes. Under boost the temp gauge stays normal. After I stop It may go up a little. But as soon as I drive it goes down instantly. My fan is coming on, and i don't think it's a head gasket. Car still is normal and pulls great.
This morning before i went to work, I pulled the radiator cap off and let it warm up. Before i knew it the coolant was not flowing threw the system, but it was ready to spill over out of the radiator. Sounds like a Air pocket to me. Let me know what you guys think.
Oh yeah. My over flow tank climbed a little as well.
EDIT:I think I figured it out........I said My fan was coming on..but it's really not. can someone tell me where the fan fuse is under the hood. i lost me cap to it when I was at the movies setting my stock alarm . If that's not blown what can cause the fan to come on sometimes and not others?
Modified by HybridcivicLS-T at 7:28 PM 10/16/2003
Old Oct 16, 2003 | 08:25 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Would this be an air pocket in my system? (HybridcivicLS-T)
somebody knows the answer.
Old Oct 16, 2003 | 08:26 AM
b18bturbo's Avatar
could be failing water pump or head gasket. Is there alot of air bubbles in the coolant system..
Old Oct 16, 2003 | 08:27 AM
green_GSR's Avatar
If you have a air pocket in the system, you should see air bubbles when you start up the car with the rad cap off. You may not able to see the coolant flowing through because the thermostat stays shut until you reach the normal operating temperature. There are a couple of bypass holes in the thermostat, but I doubt there will be enough flowing through to let you see the coolant circulating the radiator.
If you really want to see if there is air in the system, just let your car idle until it reaches its operating temperture (thermostat opens) with the rad cap open.
yellowturbo's Avatar
no it is probably your thermostat... it hapened to me...
Old Oct 16, 2003 | 08:28 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Would this be an air pocket in my system? (b18bturbo)
New water pump........not even 7months old.
Old Oct 16, 2003 | 08:30 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (yellowturbo)
I put a new thermostat in as well...O'reilly Thermostat. 7 months ago.
Old Oct 16, 2003 | 08:31 AM
green_GSR's Avatar
Try to do a complete bleed in the system and see what happens.
In addition, I think it's perfectly normal that the thermometer needle rises when you're idling. The coolant actually heats up when you're idling, unless you have a thicker rad and a high performance cooling fan.
When your car starts rolling, the amount of air flowing through the radiator is much higher than your cooling fan. That's why you see the needle goes back down.
Old Oct 16, 2003 | 08:32 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Would this be an air pocket in my system? (green_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green_GSR &raquo;</TD></TR><TR><TD CLASS="quote">Try to do a complete bleed in the system and see what happens.</TD></TR></TABLE>
7months...Im not losing coolant niether.
Old Oct 16, 2003 | 08:53 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Old Oct 16, 2003 | 10:09 AM
ekb18c's Avatar
bleed your system and find out if it solves the problem or not. If you bleed the system and it still overheats then you can look different problems.
Old Oct 16, 2003 | 10:46 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Would this be an air pocket in my system? (ekb18c)
I'll do the bleeding
Old Oct 16, 2003 | 11:55 AM
espanol's Avatar
get rid of that stock radiator and oreily's thermostat.
Old Oct 16, 2003 | 12:00 PM
boosted_dc2's Avatar
Default Re: Would this be an air pocket in my system? (espanol)
when im driving my temp guage is at 160-170 when i stop at a light it clibs sometimes to 205 then the fan kicks on. i thinks its normal, i have a new thermostat and fluidyne radiator, and new water pump.
Old Oct 16, 2003 | 12:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">get rid of that stock radiator and oreily's thermostat. </TD></TR></TABLE>
I have an Si-dual core. They should do.
Old Oct 16, 2003 | 01:11 PM
vtec.dc2's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">O'reilly Thermostat.</TD></TR></TABLE> try running stock thermostat.
Old Oct 16, 2003 | 02:54 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (vtec.dc2)
I plan on doing that. Maybe my faithful O'Reilly faILED on me.
Old Oct 16, 2003 | 04:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Old Oct 16, 2003 | 04:46 PM
Foozball26's Avatar
Don't lie antwaine you know you went ricer and thats why you put that carbon fiber sticker on the fuse panel.
the fan may have come unplugged or just not getting a good connection.
test the fan by hooking power and ground up to it, but don't stick your thumb in it like I did and cut your finger to the bone.
Old Oct 16, 2003 | 07:18 PM
Bailhatch's Avatar
Default Re: (Foozball26)
there is probably a water temp sensor on the head that is used for the fan. maybe it's bunk.
Julian Coletti
Feb 20, 2017 12:46 PM
SlowB16
Feb 22, 2013 05:59 PM
dc2long
Mar 9, 2008 09:39 PM
whatan00b
Jul 1, 2006 10:45 PM
I3ooS710
69
Jun 17, 2006 08:10 AM
