wiring aem map sensor
Old Apr 17, 2008 | 06:46 PM
Lmgrcivic's Avatar
Default wiring aem map sensor
I cant remeber what wires go where on the pigtail does anyone know what color goes where or have a diagram. last thing I need to finish
Old Apr 18, 2008 | 05:27 AM
96 GSR-T's Avatar
http://www.aempower.com go to the forums, and they have all the manuals for DL
Old Apr 18, 2008 | 06:09 AM
Muckman's Avatar
Moderator in Chief
Default Re: wiring aem map sensor (Lmgrcivic)
power, ground, signal. Guess which ones are the red and back wires.
Old Apr 20, 2008 | 05:13 AM
Lmgrcivic's Avatar
Default Re: wiring aem map sensor (Muckman)
there not red and black on the car though
Old Apr 20, 2008 | 05:31 AM
96 GSR-T's Avatar
You have to get a testlight, and test which OEM wire is Power, which is signal and which is ground..... really not that hard. As you turn the key on, one wire will get power, and while you press the gas pedal, one will vary voltage which is the signal.
Modified by 96 GSR-T at 9:36 AM 4/20/2008
Old Apr 20, 2008 | 06:41 AM
DaveF's Avatar
Default Re: (96 GSR-T)
the colors on the car are
yel/wte or yel/red = 5v supply
grn/wte = ground
wte/yel = signal
on your aem map sensor (a,b,c are stamped on the black plastic connector housing)
A= ground
b = power
c = signal
Charlie Moua
Apr 18, 2012 07:56 PM
got wide
Sep 7, 2008 06:19 AM
ZenDynasty
Dec 17, 2006 11:43 PM
PINKS
Jul 11, 2006 11:57 AM
omahaturbocivic
Aug 31, 2003 10:46 AM
