wiring aem map sensor
You have to get a testlight, and test which OEM wire is Power, which is signal and which is ground..... really not that hard. As you turn the key on, one wire will get power, and while you press the gas pedal, one will vary voltage which is the signal.
Modified by 96 GSR-T at 9:36 AM 4/20/2008
the colors on the car are
yel/wte or yel/red = 5v supply
grn/wte = ground
wte/yel = signal
on your aem map sensor (a,b,c are stamped on the black plastic connector housing)
A= ground
b = power
c = signal
grn/wte = ground
wte/yel = signal
A= ground
b = power
c = signal
PINKS
Jul 11, 2006 11:57 AM
