will these internal work?
Old May 13, 2009 | 10:06 AM
EG6 Love's Avatar
Default will these internal work?
i have a 98 b18c5 block sleeved to 82mm and i'm using an LS crank.
i found some new 82mm cp pistons for a b18b and i also found some new b18b eagle rods.
will these pistons and rods fit?
thanks, doug
Old May 13, 2009 | 11:42 AM
redlinetuning's Avatar
Default Re: will these internal work?
compression height on the B18b pistons are different from the B18c5 pistons. You're best with going with B18C5 crank, rods and pistons @82mm.
Old May 13, 2009 | 12:13 PM
kyden's Avatar
yes they will fit. you're supposed to match rods to crank anyway.
forbiddenera
Engine Machining & Assembly
Sep 7, 2017 02:11 AM
sik_sol
Dec 29, 2006 08:06 AM
brasilstreet
Aug 16, 2004 04:41 PM
syndicate43
Jan 20, 2004 01:15 PM
