Will T-25 work?
Old Nov 23, 2001 | 09:20 AM
jacobkatz's Avatar
Default Will T-25 work?
hey i'm wondering if a garret t-25 turbo off a 2g talon will fufill my needs. on a b18b, stock internals, i only want to push like 8 psi max ??
any comments
Old Nov 23, 2001 | 09:54 AM
supergreenNA1's Avatar
New User
Default Re: Will T-25 work? (jacobkatz)
that thing is going to spool up instantaneously but will die out in the top end. expect low horsepower numbers. at least go t3.
Old Nov 23, 2001 | 11:06 AM
Suprdave's Avatar
Default Re: Will T-25 work? (supergreenSol)
You should get the new Hogged Out T-25 from Forced Performance.
That is, if you already have a T-25 Manifold and stuff.
Suprdave
Old Nov 23, 2001 | 11:34 AM
BoostedB16's Avatar
Banned
Default Re: Will T-25 work? (Suprdave)
what is the hogged out t-25? Can you do anything to a td04 to make it better?
Old Nov 23, 2001 | 01:37 PM
Finest's Avatar
Default Re: Will T-25 work? (BoostedB16)
The t-25 is SMALL. Even on a 1.8L, it'll still be too small. I suggest the 14b from an older DSM for a bit better top end. Either way you still need a custom manifold.
Old Nov 23, 2001 | 02:47 PM
Suprdave's Avatar
Default Re: Will T-25 work? (Prelude_RCR)
The Forced Performance T2525 I think?
DSM Turbo...good for 11s @ like 12x ina DSM.
Stock T-25 Housing that are Machined for a ******* Huge Wheel.
Bet it would be badass ina Honda.
Suprdave
Old Nov 23, 2001 | 07:32 PM
Smashback's Avatar
I wouldn't bother spending money on a fancy T25 when you could get a T28 probably for less.
Old Nov 23, 2001 | 07:44 PM
EightOhOne's Avatar
Default Re: Will T-25 work? (mplex2000)
which turbo comes in the starion?? Not the one that looks like the conquest..but the older one? anyone know?
Old Nov 23, 2001 | 07:51 PM
MiraiZ's Avatar
Default Re: Will T-25 work? (EightOhOne)
t25's are street legal (in most places) because of the internal wg, bt produce minimal power
Old Nov 23, 2001 | 09:12 PM
Rob03Pro5's Avatar
Default Re: Will T-25 work? (MiraiZ)
T25's are very small. You can boost more than 8psi on that smallish turbo with the B18b. Look for a drop in hp after 5k rpm.
Old Nov 24, 2001 | 08:33 AM
jacobkatz's Avatar
Default Re: Will T-25 work? (Rob92SC)
so t-25 is a bad choise? i am looking for a turbo off of a turbo car. i am planing on custom building an exaust maifold. why will i loose power on the top end? where can i get a t-28 or a T-3 from?....oh ya i also want an internal waste gate.
ok thanx for the imput guys
Old Nov 24, 2001 | 04:05 PM
New User
my first turbo kit used a t3 off a ford 2.3 turbo engine. it is found in the merkur xr4ti, the turbo mustang and the thunderbird turbo coupe. its a garrett t3. the one i used came off a car with 100,000 plus miles but the turbo was in excellent condition. when i pulled it off to upgrade about 20,000 miles later, it still had no shaft play. it worked very well on my 1.6. not sure about an ls though.
Old Nov 25, 2001 | 12:00 PM
jacobkatz's Avatar
so would a t-3 off a ford be good for for a b18b? do they have an internal wastegate? if so what is it set at? what is the max psi it can push? ok
Old Nov 25, 2001 | 05:01 PM
New User
like i said.. im not sure how it will work on an ls. i don't want to mislead you. the ford engines are 2.3... so i can assume it wouldn't be too bad. i used an external wastegate with my kit but the ford setup does use an internal wastegate.
Old Nov 25, 2001 | 05:15 PM
ForcedAccord's Avatar
Texas B*tch!
T3 is like the perfect size turbo for me anyways.
Old Nov 26, 2001 | 06:51 AM
jacobkatz's Avatar
Default Re: Will T-25 work? (ForcedAccord)
what would be better for my application, a T-3 or a td-05 of a 1g talon?
Old Nov 26, 2001 | 06:53 AM
VTC_CiViC's Avatar
Swap out the wheel from a 14B to a super 16G or 18G with the sane TD05 housing and you have a good 350+hp producer.
Old Nov 26, 2001 | 06:59 AM
RGAZ's Avatar
New User
A t3 would be better. The t25 on my 1.6 runs out of breath at 6000 rpm. The 1st gen talon model won't be much better.
Fast spool up though.
Randy
Old Nov 26, 2001 | 08:55 AM
jacobkatz's Avatar
Default Re: Will T-25 work? (RGAZ)
ok then, what is the next step up from a 14b? a 16g ? on what vehicals can that be found?
Old Nov 26, 2001 | 08:57 AM
Smashback's Avatar
I don't think it comes stock on anything you'll find in the US. You have to buy one and they usually cost more than a T3/4.
You might want to save yourself some hassle and go with the "norm" like I ended up doing.
Old Nov 26, 2001 | 08:59 AM
Smashback's Avatar
Yeah T3 is a good moderate turbo. Snag one off of a Thunderbird.
Old Nov 26, 2001 | 11:40 AM
jacobkatz's Avatar
what is the wastegate set at on a t-3 off a thunderbird.how much psi can it push max? can you interchange the spring on a internal waste gate?
Old Nov 26, 2001 | 12:53 PM
dbman96's Avatar
New User
If you snag a turbo off a T-bird or Merkur with the 5-speed tranny they come with a T3 super-60 which is one of the better matched turbos for a fast spooling integra setup.
Old Nov 26, 2001 | 04:58 PM
AshlandSi's Avatar
Default Re: Will T-25 work? (dbman96)
Just because a turbo uses a T25 flange doesn't mean it's smaller than a T3. In fact, the HKS ball-bearing turbos use T25 flanges and are huge.
However, the T25's off the 2nd gen DSMs are indeed dinky little things.
[Modified by AshlandSi, 6:00 PM 11/26/2001]
Old Nov 26, 2001 | 08:06 PM
jacobkatz's Avatar
Default Re: Will T-25 work? (AshlandSi)
ok what is better and why.
T-3 compressor A/R .60, turbine A/R .48 or
T-3 compressor A/R .60, turbine A/R .63 ????
