Will this stand a shot?
Old Jul 13, 2003 | 01:20 PM
Hatchd's Avatar
Default Will this stand a shot?
Ok, I plan on building my block up over the winter(JE 11.5:1 pistons, eagle rods, sleeves, etc). I would like mid-13's or so all motor and then spray it after it's all built up. Will the motor be able to withstand this? I keep getting tons of different info. Some people tell me spraying is liek turbo and I must use lower compression pisons. Other people tell me as long as I sleeve it I can do pretty much damn near anything I want, like spraying up to a 150shot on a fully built motor. Any help here? I wanna know this before I actually build the motor so I don't spend money on something I don't need to. Thanks for any help.
Chris
Old Jul 13, 2003 | 01:49 PM
tegasaurus's Avatar
Default Re: Will this stand a shot? (JapTendencies)
if its tuned you'll be just fine. however you'll need to tune on something a little better than 91 octane. I would go for 10.8:1 or 11:1 on your setup with 91 tuned... anymore than that you'll need 94 or so
-ryan
Old Jul 14, 2003 | 11:41 AM
Hatchd's Avatar
Default Re: Will this stand a shot? (tegasaurus)
Well, around here 93 octane is pretty readily available. Is that high enough? Will that 2 octane difference make any difference in the motor?
Chris
Old Jul 14, 2003 | 12:15 PM
redlinegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">if its tuned you'll be just fine. however you'll need to tune on something a little better than 91 octane. I would go for 10.8:1 or 11:1 on your setup with 91 tuned... anymore than that you'll need 94 or so
-ryan</TD></TR></TABLE>
Hit it right on the dot. i have a 11:5:1 motor right now UNBUILT and i have no problems. The key is in tuning. Air to Fuel correctness is imperative!!!!! In fact nitrous loves high compression with the correct components!!!
spoolinegsr
Dec 26, 2006 02:28 PM
.13lank.
Sep 27, 2006 12:29 PM
dohcMONSTER
12
Apr 1, 2006 08:24 AM
blacksihatch
Nov 29, 2005 06:05 AM
Type RS
Jun 10, 2004 01:38 PM
