Will this pump work on a non sump application.
Old Oct 31, 2006 | 06:31 PM
JDMCRX's Avatar
Default Will this pump work on a non sump application.
Ok this is the scenario i need a pump thats -10 fiting and can be used for NON sump application. will the aeromotive 11101
http://www.aeromotiveinc.com/pdetail.php?prod=3
Will this work as a suction pump?
Old Nov 1, 2006 | 02:27 AM
JDMCRX's Avatar
Default Re: Will this pump work on a non sump application. (JDMCRX)
anyone?
Old Nov 1, 2006 | 03:43 AM
Dollar_bill
Guest
Posts: n/a
A sump application would be your best bet,any other setup might result
in serious starvation.
This is what i use, hope it helps.
http://www.full-race.com/catal...d=883
Are you going to use stock fuel tank or fuel cell?
Old Nov 1, 2006 | 04:09 PM
JDMCRX's Avatar
Default Re: Will this pump work on a non sump application. (Dollar_bill)
The car is a nissan skyline r32 they run a plastic tank and Right now we are not gonna be doing a tank. Cars a money pit. Im just wondering what other options we have right now i need a -10 fuel pump that can suck. Ill post a pic of the fuel system in a bit
Old Nov 1, 2006 | 05:48 PM
redboost10's Avatar
i have seen a few people on here running external fuel pump setups with no sumps, cannot remember their ht name but they are just using the drain fitting as the outlet. i dont remember reading anything about them having problems
Old Nov 1, 2006 | 05:51 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Will this pump work on a non sump application. (redboost10)
no, the a1000 is not a suction pump, it doesnt self prime. it has to be mounted below the fuel level of the tank
Old Nov 1, 2006 | 07:04 PM
JDMCRX's Avatar
Default Re: Will this pump work on a non sump application. (wantboost)
I was gonna mount it on the bottom of the car
use the upper sending unit with the line running down to the lower chassis then the pump.So technialy it will be fed by gravity cause it will be lowest point??
Old Nov 1, 2006 | 07:26 PM
wantboost's Avatar
Who is Mr Robot?
it wouls still have to suck the fuel up the pickup. hence it wont work
Old Nov 2, 2006 | 02:46 AM
JDMCRX's Avatar
And probly under hard acceleration it will startve also. I guess im gonna have to use the bosch 044 pump just need to get fittings to go from -10 feed to -6 inlet then -6 out let to -10.
Josh
riki_333
Dec 18, 2012 07:53 PM
maddcrx
May 10, 2008 10:38 AM
maddcrx
May 9, 2008 07:29 PM
EGJDM
Sep 21, 2004 07:02 PM
RicedREX
Dec 21, 2003 04:27 PM
