Will this oil restrictor work?
Old Jun 30, 2004 | 08:36 PM
MooreBoost's Avatar
Default Will this oil restrictor work?
Will this oil restrictor work for a 14b turbo? Thanks.
http://www.atpturbo.com/Mercha...e=OIL
Old Jun 30, 2004 | 08:51 PM
Muckman's Avatar
Moderator in Chief
Default Re: Will this oil restrictor work? (tegunderpressure)
Would also like to know what the ideal hole size is for one of these restrictors.
Old Jul 1, 2004 | 02:01 AM
Smashback's Avatar
When I first turbo'd my d16, I had oil blowing past the seals with a -4 line. Replaced it with a -3 line and problem solved. Although...if you're going to use that restrictor (and it looks reeeeeeally small) I'd buy one from somewhere else....$14 seems like a rip off. I think you can get those from Sunpro or Autometer alot cheaper....it's a standard fitting made of brass for goodness sake
Old Jul 1, 2004 | 07:17 AM
MooreBoost's Avatar
Default Re: Will this oil restrictor work? (Smashback)
Hmm, there is also another guy selling an oil filter to go into my -4an line, he said that would decrease my oil pressure. But I also hear of alot more people switching to -3an and solving their problem. If I were to switch to a -3an I would have to change my block adapter and turbo adapter wouldnt I?
Old Jul 1, 2004 | 07:30 AM
cheapturbolines.com's Avatar
You are best off using a -3 feed line so you don't need the restrictor band aid.
Old Jul 1, 2004 | 07:39 AM
MooreBoost's Avatar
Default Re: Will this oil restrictor work? (cheapturbolines.com)
Thats kinda what I was thinking. I am using a Stealthmode oil line kit, so what else will I need to switch to -3an? Will I have to change the block adapter and turbo adapter?
Old Jul 1, 2004 | 07:46 AM
Honda Hick's Avatar
I would just change to a -3an line. I have yet to see a real analysis of what those oil restrictors actually do, like a pressure test before and after the restrictor. Who knows how it is affecting the pressure.
Old Jul 1, 2004 | 07:50 AM
Muckman's Avatar
Moderator in Chief
Default Re: Will this oil restrictor work? (Honda Hick)
Well its obvious it would decrease the flow of oil volume. But whether its too much of a decrease or not, thats my question.
Old Jul 1, 2004 | 07:52 AM
MooreBoost's Avatar
Default Re: Will this oil restrictor work? (Muckman)
Forget the restrictor.
What I need to know is if I need to change the fittings on my block and turbo in order to accept the new -3an line. And if so, which in particular will I need?
Old Jul 1, 2004 | 10:36 AM
MooreBoost's Avatar
Up.
TravisBiggie
Apr 24, 2012 08:01 PM
tuhboek
Jun 21, 2010 05:51 AM
Ad4mGSR
Jul 23, 2004 01:15 PM
silverpenny
Apr 28, 2003 06:54 AM
ziggity
Jan 10, 2003 11:56 AM
