will my clutch be able to handle?
well i started off with a stock b16 turbo and den went to built block turbo set up.. i have a exedy stage 2 clutch... now im upgrading the turbo to a gt30.. wuld the stage 2 stil be able to handle it? here are some of the specs.. 84mm JE pisons, 8.3:1, sleeved block, eagle rods and acl bearings.. it will be my daily driver but at low boost but will tune to high boost so its safe for track days.. how wuld my clutch do?
I've been wondering the same thing...i have the same clutch in my turbo GSR, but i dont remember the exact torque rating on it. I believe its in the middle 200's somewhere....bump for more answers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovey408 »</TD></TR><TR><TD CLASS="quote">upgrading the turbo to a gt30.. wuld the stage 2 stil be able to handle it? how wuld my clutch do?</TD></TR></TABLE>
It all depends on how much you boost, but it's really how much torque you're producing.
What is your current clutch rated at?
I don't really know what the exedy stage 2 clutch is rated at, but it should be around 210 to 270 ft/lbs of torque. Someone can probably answer this.
As of right now you are fine, but once you start boosting higher and getting mad torque your current clutch will have to be upgraded.
GOOD LUCK!!!
GOOD LUCK!!!
I'm running that same clutch going on 4 years/12000 miles. I have a very short but sweet comute to work. I rape it to 80-100mph everyday almost and stil holds strong. I'm putting down 250whp on a stock block b16 at 10psi. That clutch is rated at 275tq. I bought for around $250. on ebay way back then, not bad.
yeah I have that clutch on my boosted GSR and its rated to about 280 ft. lbs. great feel, sorta like stock but stronger of course. doesnt chatter like the ACT
Like i said in my earlier post, i have the Exedy 2 and have run it for 2 years ~300whp without issue. For my new build, i am upgrading to something else though. I dont want to risk having to pull the engine again because i toasted my clutch. I'm deciding between the Clutchmasters FX400 and the Competition Clutch Stage 4/5.
elitesi8
Nov 23, 2005 05:19 PM
SneezR
Mar 3, 2005 06:06 AM
