Will Hondata work on this setup???
Old Nov 13, 2003 | 12:38 PM
jon_'s Avatar
Default Will Hondata work on this setup???
I have a 2001 Civic, which is turboed. I am running the MF2 with two extra injectors(which sucks) so I was wondering if I got an OBD2->OBD1 conversion harness and hondata would it work? Or should i just go with something like the E-Manage...Only shooting for like 4 psi daily and 8 psi for racing, until I build my block...
Old Nov 13, 2003 | 01:45 PM
HXMan's Avatar
Default Re: Will Hondata work on this setup??? (jon_)
Good question. You might want to email honda and see if they can do anything for your application.
I am thinking hondata may work, but I don't know if they make adaptors for 01+ Civics? I bet they use a different connector configuration then the 96-00 cars.
Old Nov 13, 2003 | 02:00 PM
Adriano's Avatar
Default Re: Will Hondata work on this setup??? (HXMan)
isn't hondata just for obd1?
Old Nov 13, 2003 | 02:42 PM
PHiZ's Avatar
The D17 is that you have the returnless fuel system, hence the extra injectors fuel managment. I don't THINK hondata can control the extra injectors, I do believe EMS can.
That's a start to your research, but not an all-encompasing answer.
-PHiZ
Will_H
May 11, 2010 02:22 PM
mkw1
Jan 9, 2008 05:24 PM
hondamanwill
Jan 4, 2004 07:10 AM
i3oricua
Jul 8, 2003 11:05 AM
