Will this be high enough for my catchcan?
Old Aug 26, 2005 | 10:40 AM
N20civicB18's Avatar
Default Will this be high enough for my catchcan?
I am installing my Endyn Catchcan kit and I cant seem to find room in my EG that is up high. In a past honda-tech thread I found this. Could I mount my catchcan like this or is it to low?
(That is not a Endyn but you get the point)
Any other suggestions?
Old Aug 26, 2005 | 10:45 AM
King Tut33's Avatar
Default Re: Will this be high enough for my catchcan? (N20civicB18)
I was able to mount my Z10 to the strut tower in my EH-3. I don't have a good pic of it though. It was mounted under where the wiring harness is mounted to the strut tower.
Old Aug 26, 2005 | 10:51 AM
Is the oil return the only reason it needs to be so high?
Old Aug 26, 2005 | 10:53 AM
King Tut33's Avatar
I would think that would be the reason. I didn't run a return line on mine. It had a plug at the bottom for draining.
Old Aug 26, 2005 | 11:04 AM
ladysman's Avatar
Default Re: Will this be high enough for my catchcan? (King Tut33)
Old Aug 26, 2005 | 11:10 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Will this be high enough for my catchcan? (ladysman)
its too low, it needs to be mounted above the port level on the back of the block
Old Aug 26, 2005 | 11:12 AM
dont mind this post, my computer is now showing any post except my first one unless i post...? I tried 3 computers on my LAN it does the same thing? never did this before?
Old Aug 26, 2005 | 11:13 AM
Default Re: Will this be high enough for my catchcan? (wantboost)
I know it needs to be mounted higher for return reasons but if im not using the return does it have to be higher?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">its too low, it needs to be mounted above the port level on the back of the block</TD></TR></TABLE>
Old Aug 26, 2005 | 11:14 AM
wantboost's Avatar
Who is Mr Robot?
then its just gonna fill up with oil residue and ****. run a drain back
Old Aug 26, 2005 | 11:29 AM
seen4ever's Avatar
try it on the passenger wheel well strut tower area, there are two holes that line up pretty perfectly for it.
Old Aug 26, 2005 | 11:33 AM
King Tut33's Avatar
Default Re: Will this be high enough for my catchcan? (seen4ever)
Yep that is just about where mine was mounted. It worked great on my NA car and I didn't get any major oil or sludge in it.
Old Aug 26, 2005 | 11:34 AM
well obviously i would be draining it, I dont want to run it back after reading all the posts on what the residue inside of there actually is, its more gasses then oil
Old Aug 26, 2005 | 12:18 PM
seen4ever's Avatar
i run it back without any issues, unless you have really bad leakdown and alot of fuel is making it past your rings, it should for the most part be oil.
Old Aug 26, 2005 | 02:48 PM
yee SERIOUS's Avatar
man...where would you mount that thing in an integra?! that's like no room at all. i can't even find a place for my msd box.
Old Aug 26, 2005 | 03:25 PM
itr1143's Avatar
think about this..if you are going to run the drain back with the pcv on top of the catch can..why would you waist the cash on something that would do the same thing the tank on the back is doing..i have a new type r build and i do not drain back..and after drianing the ish out of my can..on why i would ever drain back....
Old Aug 26, 2005 | 03:32 PM
Dr Pooface's Avatar
Default Re: (LiTtOGPiMp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">man...where would you mount that thing in an integra?! that's like no room at all. i can't even find a place for my msd box. </TD></TR></TABLE>
right here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">
Just remove the wireing harnesses and let them hang in the engine bay.
Old Aug 26, 2005 | 06:28 PM
wade's Avatar
Default Re: (Dr Pooface)
wadefab!!!!
sorwdfish
11
Aug 13, 2013 08:14 PM
CptHMCrunch
May 14, 2013 04:55 PM
green_eg_hatch
Feb 8, 2010 01:57 AM
Sum Dum Phuc
25
Dec 29, 2004 01:30 PM
