will a btm cause noise?
Old Mar 26, 2003 | 04:00 PM
crxY-49's Avatar
Default will a btm cause noise?
I installed my btm in my crx today and it runs great. However, is it normal to be able to hear the increased sparks? I can hear my sparkplugs clicking from inside my car. thanks.
Old Mar 26, 2003 | 05:11 PM
crxY-49's Avatar
Default Re: will a btm cause noise? (crxY-49)
Old Mar 26, 2003 | 06:20 PM
crxY-49's Avatar
Old Mar 26, 2003 | 07:09 PM
BoostedSi's Avatar
thats pretty weird. I never had any clicking sounds with my 6btm and regular btm. I dont think it should do that.
Old Mar 26, 2003 | 07:11 PM
avividmemory's Avatar
Default Re: will a btm cause noise? (BoostedSi)
how is the spark increased when the sole purpose of it is to retard the timing? and no, mine is quite, my dsm injectors are loud though...
Old Mar 26, 2003 | 09:10 PM
crxY-49's Avatar
Default Re: will a btm cause noise? (SpoolinLS)
its an msd btm...which increases spark along with retarding timing.
Old Mar 26, 2003 | 10:15 PM
ion_four's Avatar
umm...I don't think there is any way you could hear the spark since it's inside the engine...it's either your injectors, your valves (which would suck) or something else is screwed up. I installed my 6btm and it ran great for about two minutes, then the stock coil burnt out, but after I installed an MSD it was fine and makes no noise.
::EDIT::
Maybe something is hitting inside your dist cap, since you obviously opened it up?
[Modified by ion_four, 7:15 AM 3/27/2003]
Old Mar 26, 2003 | 10:24 PM
Smashback's Avatar
Default Re: will a btm cause noise? (ion_four)
you hear it through the speakers...msd makes a power isolator for it. like $50 or something at summit.
too bad after my swap i can hear my alternator whining thru the speakers when the stereo is on
Old Mar 26, 2003 | 10:26 PM
falcongsr's Avatar
What is this crap?
Default Re: will a btm cause noise? (Hatchblack)
EMI owns you!
i just took a 2 day seminar on it for work
Old Mar 27, 2003 | 08:23 AM
Smashback's Avatar
Default Re: will a btm cause noise? (falconGSR)
Sweet, so when are you gonna come fix my whirring stereo problem?
kyleeuuu
Feb 1, 2009 09:33 PM
d_mina
Jun 25, 2004 02:20 AM
bananas
Apr 16, 2004 04:43 PM
GruvyTune
Feb 10, 2002 02:05 PM
GruvyTune
Feb 6, 2002 04:45 PM
